Hello folks
Im installing my Christmas present in to my work table
and was looking for a pencil or tracing of the hole required.
will a standard commercial table opening work .
can i mount an oil pan for it just oil manually at oil for
When you think your someone of importance.
Go try ordering someone else's dog around
Hello folks
A standard industrial sewing machine table has a 7" x 19" cutout. The knee lever mounts in a common general area. The oil pans have a cutout for the knee lever to operate. If your machine will drop into a 7" x 19" cutout, with hinges lining up with the pins on the table and the rubber stoppers in the corners catch the edges of the machine, you're good to go. If not, you'll need to either brace the hole in the table with solid wooden supports, or route out a larger space, to match the base of the machine.
Edited by Wizcrafts
Posted IMHO, by Wiz
I have just finished my first "special" base for a 132k6 - with no pattern - and for a paying customer!!
Take your time, sketch it out and work out what is going to be your reference point. I used the centreline of the belt slot but something else may jump out as being more logical to you.
If in doubt then do one in heavy cardboard so you can sit the machine in the mounting hole and put the motor upside down on the three bolt holes so you can check the alignment of everything. Come to think of it that may not be a bad way to start the process!
Darren Brosowski
Thanks much for the response was hoping a standard table would work. Didn't have one to check but found one at a market days.
Great thanks for the help. Talked to mr kovar and soon as I got the cash ill be getting a motor
From him along with other needs.
Once again appreciate the help.
