Long time no post. Ive been in the hospital. I finally escaped and can do leather work again. :)
Where are people buying T nuts for IWB holsters? Also what size is a good size to get?
Thanks for the help I cant get the search to work on single letter searches.
Michael
The key to immortality is first living a life worth remembering.
Bruce Lee
McMaster Carr is a great source. i use the 8-32 T-Nuts
Tony
The hand that feeds you also puts the chains around your neck.
Grainger or MSC are also good sources. I use mostly 6-32's but I have 8-32's also.
Ace hardware
Diapers and Politicians should be changed often...
Both for the same reason!
I had my local hardware store order me a full box of 6-32 nuts from Midwest Fastener. Much cheaper than buying them individually. You can't order from them yourself.
If people are having trouble finding these, I will send you 4 of them for a $4 paypal. I recomend you buy them locally, but if you can not find them it is an option. I have both #6 and #8.
Aaron
Thanks for the information everyone.
Aaron, thanks for the offer. Ill look around but will let you know if I cant find them.
Michael
Bruce Lee
McMaster-Carr sells them in packs of 100 for just over $7. I'm going to order some next week.
I use 8-32 size, and they are available at all my local hardware stores.If I wanted to buy them in bulk I would get them from Fastenal or McMaster-Carr. They have regular zinc plated ones... I would like to know where to get Black T-nuts???
I just ordered stainless t nuts from steelmarinefasteners.com $36.30 box of 100. The stainless is more money but I think it is worth it, I hate corrosion.
They are 8/32 x 1/4 sku NTEENUT8-32, shipped fast. You may have to shorten them for thinner leather but on 9-10 oz they protrude just slightly. I also ordered the screws from them, $4.44 box of 100. I got the size and material off a Bianchi holster, they use stainless. I did find i needed to make the head smaller to fit the snap socket well. Easy to do, put the screw in a drill and run it against my belt grinder.
I like stainless.
Jeremy
