I currently have my Cowboy 4500 set at 18 for two layers of 7oz leather, but I feel the machine can go faster, and I know I can go faster now. How fast can I crank the machine up?
It has the newer digital motor on it, not the knobs.
I set my motor at full speed; 3800 rpm. The servo motor is still controllable enough to slow down with my tippy toe, to 1 stitch per second.
3800 rpm at the motor, with a 2" pulley, divides by 4.5 via the large 9" pulley on the speed reducer. The small 2" pulley on the reducer feeding the large 8" pulley on the machine gives another 4:1 reduction, for a total of about 8.5:1 reduction. 3800/8.5 = 447 rpm. 447/60 = ~7 stitches per second, maximum.
To sew at this speed I had to replace both belts with almost perfectly true belts that didn't have sideways motion. I also loosened the motor bolts and repositioned it for minimum side pull on the belt to the reducer. I also moved the reducer inward, toward the machine, to get the machine pulley directly inline with the small pulley on the reducer. Without those modifications the machine shook everything off the pedestal table at full speed. Now it just shakes a little.
I purchased a 64 inch belt at the same time that I replaced the 39 and 58 inchers. By hooking the 64" belt to the middle pulley on the reducer I can sew at about 15 stitches per second. The shaking is only slightly worse than at 7.4 spi. The trueness of the belts and alignment between the motor, reducer and machine pulleys makes all the difference in the world, if you need to sew fast.
Also, I tightened down every nut and bolt on the pedestal base and table.
Edited by Wizcrafts
Posted IMHO, by Wiz
What are you stitching?
And what's your hurry?
Rayban
www.rgleather.net
Gun belts. I am running 15 or so a week and will be expanding with a couple of stores stocking my products.
Are there signs to look for that I am going too fast? I just want to cut down my sewing times, I have cut a lot of time out of my process with using a bluegrass edger, a roller to apply glue, making templates for all my holes and the areas of the belt I don't glue. I want to be as hand made as possible, but speed things up. I have a full time job and currently sell EVERYTHING I make. Within minutes of posting an unpaid order for sale, its GONE. I had a glock holster a guy backed out on last 15 seconds! I am just trying to make some more $$$ so I might be able to make this a full time gig, and to get some more equipment.
Nick
Kcinnick,
You'll know you are going too fast if you screw something up. The machine will stitch just fine at a high speed, you just won't be able to control the placement of the stitches very well. If you have an edge guide, that will help. Speed isn't everything. I learned that the hard way. Just turn up the speed until you get to a point where you don't feel like you are in control. If you go too fast, and ruin a belt, you'll have to remake it. Those few seconds you save by going as fast as possible will be lost 100 fold when you have to remake that belt.
Kcinnick,
What is great about the motor is the speed settings. I can feather the peddle to get different speeds, I can set the start speed at whatever I want, and the top speed. I have the slow setting, must be 1/2 a stitch a second, it is where I do the point at that speed, heck, I hand wheel the last stitch at the point. I am not looking to go super fast, but, would 2-3 stitches per second be reasonable? I have an edge guide, it works amazingly well, but I think i want a drop down style one for more versatility. The machine came set up at 18, I didn't know if there was a reason for it or not, but I assume it goes to 100... When I sew holsters I drop it down to 6 since 1/2 the work is free hand, but I just want to speed up belt straight lines.
Nick
I have the same machine. You should be able to sew 2 - 3 stitches per second easily, especially on a belt. I think I stitch faster than that on holsters (not around corners, but on straight sections). You just need to experiment with the speed settings and find what you are comfortable with. We can't tell you what speed setting to run. Just get some scrap leather and experiment.
I can tell my limits, I just want to know the machines limits!
That's easy: 800 RPM at the machine.That equals about 13 stitches per second. Keep it very well oiled if you sew at that speed on a regular basis.
The same speed applies to the Cowboy 3500 and 5500, Cobra Class 3 and 4, and all other brands of 441 machines.
Due to vibration issues, I would limit the top speed to 10 stitches per second on the big stitchers, or 600 RPM at the machine.
Posted IMHO, by Wiz
