Unless you are comparing the big Adler 30-70 to the Singer 29k172, they are very similar in capabilities. The Adler 30-7 clears a little more thickness than the Singer 29Ks. Aside from that, they use the same bobbins and needles and deliver about the same maximum stitch length of no more than 5/inch, into 8 ounces of leather.
The Adler 30-70 is a a whole nuther machine. It sews 3/8 inch, delivering a solid 5 stitches per inch, or longer, and uses system 332LG long needles. I sew on one every week at M&M Leather. It uses a 1/2 HP clutch motor.
Edited by Wizcrafts
Posted IMHO, by Wiz
Thanks, Do you have a picture of the 30-70 ?
I don't own the machine in question. But, I found a good photo of an Adler 30-70 on this blog
Posted IMHO, by Wiz
Thanks Again, Is the 30-70 marked on the machine somewhere?
Yes, it is engraved into a metal plate on the head, on the right side of the body. There is nothing else like the 30-70. If it says Adler on top and looks like the machine in the photo, it is a 30-70.
Most of the Adler 30-70 machines are motorized with 1/2 hp clutch motors. These motors have adjustable freewheeling room when you slightly depress the floor pedal. Without this free play, you cannot hand wheel the machine at all. I would not use a patcher than can't be hand wheeled.
Posted IMHO, by Wiz
Thanks, I am going to an auction and they have a Alder patcher, but I am not sure if it is this model,I have a singer 29k172, it has a 3/8" clearence, Is this 29k172 the same as the Adler 30-70 and are these the biggest patchers available?
If your 29k172 is a like Chevy 1500 truck is to a sedan, the Adler 30-70 is a like a 2500 model. Everything is beefed up.
I have a Singer 29k172 and it is not the machine that my buddy's 30-70 is. The 30-70 has longer needles and sews thicker leather. It pulls a tighter stitch. It actually sews 3/8 inch, where our machine only clears about that much. The foot needs to lift off the top of the leather and move all the way forward and backward to get effective stitch length.
The Singer 29k172 is more similar to an Adler 30-7. This is usually a treadle machine on a cast iron base and is not typically motorized. It sews about the same thickness as the 172.
Other than that, they use the same bobbins and the presser feet are similar. I can use Singer patcher feet on the Adler 30-70 by enlarging the hole for the mounting screw. There is a little slop to deal with, because the Singer feet seem to have a wider inside mounting space than the Adler.
Singer patchers use system 29x3 and 29x4 needles. Adlers use system 332 in the 30-7 and 332LG in the 30-70.
If you see the machine at the auction and it resembles your Singer patcher, but is black, it is probably a 30-7. If it looks like the one in the photo I linked to and is gray, it is a 30-70. The 30-70 has a solid flywheel; no spokes. It weighs a gazillion pounds.
The 30-70 uses a large bobbin and bobbin case.
If the machine at the auction is a 30-70, complete on a power stand and turns easily by hand, and you win it for under $1800, pat yourself on the back.
Posted IMHO, by Wiz
I was wondering why you keep asking if the 30-70 looks like a Singer 29k172, after I posted a reply with a link to view the Adler on a blog. Did you see this text link: "But, I found a good photo of an Adler 30-70 on this blog "
Posted IMHO, by Wiz
Thanks, That clears things up. the auction viewing is at the end of next week.The singer 29k72 works well but when I go to repair riding boots they are always thick down by the heel and that is where I need the extra thickness on the machine.
