Members cowcamp Posted April 18, 2012 Members Report Posted April 18, 2012 after almost a year i finally got the machine i been wanting and hearing about. found a 111-155 on ebay with all accessories and bobbin winder. works perfectly well missing nothing and got it to my door for 285.00. i know machines got a 136-101 and 29 58 and assorted others just wanting to know if there any special.tricks to em ... also if anyone has a full manual and adjusting manual if they would mind sharing a pdf copy. email is hairtriggerranchrode@gmail.com. im just gotta get a motor for it and mount it in my work Table. will a standard commercial cut out do the job also is it recommended to mount.an oiled pan or just pit the gallon of oil a day on by hand I've heard they are a hog for oil with is fine if it does.everything i anticipate. thanks much fellas Quote When you think your someone of importance. Go try ordering someone else's dog around
Moderator Wizcrafts Posted April 18, 2012 Moderator Report Posted April 18, 2012 (edited) It fits a standard 7" x 19" cutout in a standard sewing machine table. You will need the table top, with the cutout and slot for a v-belt, k-legs frame with speed pedal and linkage, a knee lever kit, a back stop, an oil pan, a bobbin winder, a motor and thread stand. I would recommend buying a servo motor, which is easier to control than a clutch. The SewPro 500GR, available from Toledo Industrial Sewing Machines, has a 2" pulley and 3:1 gear reduction built in. It bolts into the same 3 holes as a clutch motor, but usually sits 1 inch closer to the body. You are going to have to assemble everything, then use a thick tow rope to find the correct length of v-belt. Edited April 18, 2012 by Wizcrafts Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
