IngleGunLeather Posted April 28, 2012 Report Posted April 28, 2012 I haven't made any adjustments to the machine. It has been working flawlessly up until this morning. I went to sew up a mag pouch and the presser foot started sticking in the up position. I've lubricated everything and it still sticks. Quote Ingle Gun leather
IngleGunLeather Posted April 28, 2012 Author Report Posted April 28, 2012 Well, after a few minutes of double checking everything. I found that the presser foot adjustment nut was the cause. I'll readjust the pressure and tighten it up. Quote Ingle Gun leather
Moderator Wizcrafts Posted April 28, 2012 Moderator Report Posted April 28, 2012 It needs oil! Put a few drops of sewing machine oil inside the adjuster and let it drip down around the presser bar. Lift the rubber covers on top of the head and fill the holes with oil. I also remove the faceplate (two screws only) from my and my buddy's 441 machines and apply oil to all of the tiny oil holes hidden inside the face, dealing with the needle and presser bars and take-up parts. Of course, one needs to line up the arm that separates the top tension disks when reassembling the faceplate. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members DDahl Posted April 29, 2012 Members Report Posted April 29, 2012 I have a Cobra 4 and early on experienced the same problem. On my machine the tension bolt (used to adjust the tension) has the center hole a bit out of true. Thus when you rotate the tension bolt it tightens and loosens on the pressure foot shaft as you make a single turn. If your bolt does the same simply adjust the bolt to the location (during a single revolution) where it feels the easiest to turn. This means that its hole is in the best alignment with the pressure foot rod at that point. This should solve your pressure foot sticking problems (along with using plenty of oil to lubricate the pressure foot rod in its shaft). Quote
Moderator Wizcrafts Posted April 29, 2012 Moderator Report Posted April 29, 2012 I have a Cobra 4 and early on experienced the same problem. On my machine the tension bolt (used to adjust the tension) has the center hole a bit out of true. Thus when you rotate the tension bolt it tightens and loosens on the pressure foot shaft as you make a single turn. If your bolt does the same simply adjust the bolt to the location (during a single revolution) where it feels the easiest to turn. This means that its hole is in the best alignment with the pressure foot rod at that point. This should solve your pressure foot sticking problems (along with using plenty of oil to lubricate the pressure foot rod in its shaft). I concur. I just tried this (specific rotation position of pressure adjuster) on my CB4500, with the same results. Who woulda thunk it? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members DDahl Posted April 30, 2012 Members Report Posted April 30, 2012 I concur. I just tried this (specific rotation position of pressure adjuster) on my CB4500, with the same results. Who woulda thunk it? Guess which machine assemblers in China use common main casting and part suppliers for at least certain parts on their 441 clones? Interesting! Quote
Mike Craw Posted May 29, 2016 Report Posted May 29, 2016 My Cobra 4 decided to stick in the up position today, exactly as you described. Wiz, what are ribber covers? I can't find any reference to them in the parts list that came with my machine. Also, when you say remove the faceplate, are you talking about taking all the parts off so you can completely remove it, or just the plate screws so you can see inside? Thanks! Mike Quote My choice early in life was either to be a piano-player in a whorehouse or a politician. And to tell the truth, there's hardly any difference. Harry S. Truman
Moderator Wizcrafts Posted May 29, 2016 Moderator Report Posted May 29, 2016 31 minutes ago, Mike Craw said: My Cobra 4 decided to stick in the up position today, exactly as you described. Wiz, what are ribber covers? I can't find any reference to them in the parts list that came with my machine. Also, when you say remove the faceplate, are you talking about taking all the parts off so you can completely remove it, or just the plate screws so you can see inside? Thanks! Mike I meant to type "rubber" covers. I just corrected it. lol There are two bolts securing the faceplate to the left top of the machine. Unscrew them and pull the plate off. All the cranks inside have little oil holes. Failure to oil these cranks may lead to the machine seizing or binding, as happened to a friend's Cobra Class 4. He simply didn't know about opening the plate to access those little holes. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
MADMAX22 Posted May 30, 2016 Report Posted May 30, 2016 Atleast this is an easy fix. Try fixing the reverse stitch on the older 441 clones, seems it either tracks or doesnt. Quote
