I'm trying to reproduce the straps to a purse my girl has had in her family for ages. I'm at a loss on where to find the brown snaps and rivets it used. I've checked all my usual sources plus a few more ebay/etsy/google searches but I'm still coming up with nothing. 10mm size. Need about a dozen of each. Snaps & Rivets. IF anyone has some or knows where I could get some, please help me out.
Can you post a picture of existing brown hardware??
if you cannot find brown, you can always "oxidize" your own findings.
http://www.riogrande.com/Search/oxidize
fyi alot of times though there will be a clear coat on the brass, copper snaps etc that will need to come off before adding a patina.
Ive also had success with using gun bluing on steel findings.
good luck :)
http://i129.photobucket.com/albums/p238/TRF102806/Facebook/Mobile%20Uploads/415093_448633865163373_100000502890049_1698392_1326860206_o.jpg
My mistake. I thought I had. Here's a link.
I just measured my line 20 and line 24 snaps... and they are respectively 12mm and 15mm across.... so I believe you are searching for Line 16 brown snaps sometimes called glove snaps.
Zack White has some line 16 in brown.
http://zackwhite.com/xcart/home.php?cat=1060 scroll down a bit.
This place also has them in line 16
http://www.onestopcandle.com/Merchant2/merchant.mvc?store_code=OSC&screen=PROD&product_code=LE125002
