Whiteeugene, It may be that you put 2-3 coats of dye on it.. The metallic look you're talking about is dye that's dried. The solvent that carried the dye has evaporated leaving it as a powder on the surface. Be careful buffing it because it can be reactivated if it comes into contact with dampness...You might try diluting the dye and try it on a scrap piece. Good luck.
I tried several combinations today and got the same result 1 coat or 3 still gold with dry leather or damp leather maybe its went bad it's only a month old. I may just pick up another bottle. I did a belt with this bottle a few week back and it was fine the only difference was the type of leather and the water I used. I had a similar with black one time had to dye the item with cordova and then black not sure why but the black never seamed to dry. Read a post about black made a new item dyed it cordova first then black came out fine same hide. Maybe I'll switch brands.
Thanks for your help
Doug
I went by Oregon Leather this morning and they tried some leather balm it took most of the gold off but left the leather a dark purple or black with purple high lights. Tried it on a new piece with the same results, at least it doesn't look bronze any more.
Thanks for all of your suggestions
Edited by whiteeugene
This is what it looked like after I buffed it with the leather balm, nice black. I made a new one it came out a little better still not what I wanted. looks like I will have to experiment some more.
post-21288-085392400 1336778946_thumb.jp
Interesting. Did Oregon Leather tell you whether or not they had seen this type of thing before? How much color came off when you buffed the the balm?
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
They said they had seen before but not as bad, A lot of color came off when I buffed it even on the new piece.
