Members Kerry Gunn Posted May 31, 2012 Members Report Posted May 31, 2012 I have a Singer 31-15. I am pretty new at using this machine. It is not picking up the bobbing thread. Not sure what is wrong. Timing? If so how do I time it. I would appreciate any help i can get. Thanks. Quote
Moderator Wizcrafts Posted May 31, 2012 Moderator Report Posted May 31, 2012 Are you using the proper needle system (16x257, DBx1, DBx257, or 1738)? If you got the machine with the wrong needles, they may be too long or too short. If the needle is not correctly aligned it will not pick up the bobbin thread. Verify that it is fully inserted up into the needle bar and that the cutout section around the eye is on the right. The thread must feed through the eye from left to right. Have you threaded the machine correctly (see photos below)? Is the bobbin thread coming out from under the bobbin tension spring opening, as in the photo below? Is the bobbin case snapped into the retainer in the shuttle housing? If the needle is installed as I described and a threaded bobbin is in the bobbin case, with thread sticking out a few inches, and the top thread is correctly fed through the guides and tensioners, the usual cause of failed stitching is that the needle bar has slipped in its mount, from heavy impacts trying to sew hard leather and needs to be retimed. This may require personal assistance to teach you to set the eye of the needle in exactly the correct position for the shuttle point to pick off the loop.. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Gregg From Keystone Sewing Posted May 31, 2012 Members Report Posted May 31, 2012 Wiz, 'By the book', needle system for Singer 31-15 is 16X1, Singer Catalog # 2047. Now, we DO use and sell to folks system 16X87 (AKA 71X1, & 16X73), Singer Catalog # 1526, for 31-15 as well. As it is with needles, it's never straight forward. If your using 16X257 in your machine and have it set properly and it works, great, but we normally would not sell this needle for this machine. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Cobra Steve Posted May 31, 2012 Report Posted May 31, 2012 Hi Wiz and Gregg. You both are right. There are so many variances with the 31-15, but if they are set right they will all work. In a pinch, I have used home machine needles, and even 135X17 needles. Hope you both are doing well. Steve Quote Thank You Steve Tayrien Leather Machine Co., Inc. 2141 E. Philadelphia St. Unit "U" Ontario, California 91761 1-866-962-9880 http://www.leathermachineco.com cobra@leathermachineco.com
Moderator Wizcrafts Posted May 31, 2012 Moderator Report Posted May 31, 2012 Gregg; My 31-15 is very old. I believe it is older than 1920. The machine came with DBx1 needles when I got it. They are perfectly centered in the hole in the throat plate. I have some old stock of system 134 needles that I wanted to use in the machine, but, they hit to the left of center in the hole. Some work okay, others skip stitches. The DBx1 work perfectly. Maybe my needle bar was made for these needles back then. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Gregg From Keystone Sewing Posted June 1, 2012 Members Report Posted June 1, 2012 Gregg; My 31-15 is very old. I believe it is older than 1920. The machine came with DBx1 needles when I got it. They are perfectly centered in the hole in the throat plate. I have some old stock of system 134 needles that I wanted to use in the machine, but, they hit to the left of center in the hole. Some work okay, others skip stitches. The DBx1 work perfectly. Maybe my needle bar was made for these needles back then. Yeah man, no doubt. Not right or wrong, if it works, it works. My father has a few 31-15s with original paint AND original gold leaf paint. He does not have a lot of old machines, but he also has a Howe as well in his family room with stand. Some poeple go crazy over this stuff. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Kerry Gunn Posted June 6, 2012 Author Members Report Posted June 6, 2012 Thanks Gregg, Steve and Wiz. Gregg was exactly right. I did try a shorter needle and was able to move the needle up far enough to catch the bobbin thread. I am pretty new at using this and learning by trial and error mostly. I am so happy I found this site and you wonderful people. You are a great help to me!! I appreciate it. Quote
