Six months ago, I was motivated to build a stitching horse. I liked Dale Grabowski's Sit 'N Stitch and the only requirement I had was that I'd use my old motorcycle brake pedal for something.
I made a small version first and scaled it up. After a gazillion trips to Home Depot and OSH, it's done.
Check it out! I'm stitching/lacing everything I see!
Tae
nice work! i really like the way you did it with the brake pedal really creative!----sheridanman
Just moved into our new house! Building my workshop now! A Stitching Horse & Pony are two things that are definately going into the shop! Any chance you have a blueprint and parts list you'd like to share? Nearest Home Depot is 20 miles away! hahaha That is awesome!
:You_Rock_Emoticon:
:You_Rock_Emoticon:
Thanks! Here is the orig. plan, but I've made changes along the way. In the beginning, I made all pieces out of pine, but the square base piece cracked and the surface of the 2' base piece was warped. So I did surgery and replaced the square piece with oak and added a circular base. Also, I planed and sanded the 2' base piece and added a 1" oak board for flatness. In addition:
  • Jaws: I made them out of pine, but in retrospect, I should have made it all out of oak. The left over wobble is the bend in the pine jaws that I have to live with.
  • The intermediate piece is out of two (not one as in the diagram) glued square pieces of 1" oak
  • I added a circular base below that (see photo)
  • The 2' base piece was initially out of pine, but it wasn't flat enough, so I glued an oak piece, cut it at 75 degrees with my circular saw and sanded down the edges. In fact, I like that it's 2.5" thick. Th swivel idea was good on paper, but doesn't work too well, so I tighten the nut all the way.
  • In the future I will not use chrome acorn nuts. They cost me like $20 for what you see!
  • I use a leather strap. It's nice because the friction makes it stay, but in the same regard, it doesn't spring open as easily. I have to help it open by loosening the strap in the middle with my fingers. I kinda like this setup because then I don't need a racket scheme
  • I added wooden cabinet handles. It makes moving it easier and it's handy since I can stick my stitching awl in there when I stitch
  • I added rubber feet so they don't slip around carpet or scratch wooden floors.
  • I added and modded U-bolts for the strap by cutting them shorter with my dremel tool with cut-off discs.
  • I added a wingnut (with leather handles!) just in case I really want to hold it shut without my foot pressing the pedal.
In retrospect, I probably spent more than $125 that buys a stitching horse from Mr. Grabowski, but it was fun!
For materials I've bought everything at home depot (except chrome acorn nuts, avail at osh)
  • one 2"x10"x8' piece of pine
  • one 1"x10"x6' piece of oak
  • 4 U bolts with chrome acorn nuts
  • 1 3/4"x8" carriage bolt with wing nut and chrome acorn nut and 3 washers
  • 3 1/2"x3" carriage bolts with nuts and washers
  • wood glue
  • one stainless steel door hinge
  • one set of L brace (I think 2"x2") that I bent slightly using a vise and hammer to match the tilt of the pony
  • one 6"x6" bracket that I cut short fit in the circular base
  • two 6" mending brace
  • compression spring
  • one left-over leather strap that was tapered slightly from 3/4" to 1/2" along the way
  • set of screw on rubber feet
  • 4 screws
  • 2 wooden handles
  • cherry pecan stain
  • semi-gloss polyurethane
  • leather to cover the jaws -- I used contact cement
For tools, I used
  • circular saw
  • jig saw
  • hand plane
  • corded drill with sanding attachment
  • various drill bits
  • dremel tool with cut off disc
  • angle grinder (to round the edges of the cut-off bolts) -- kinda unnecessary
Have fun!
Tae
Edited by Tae
  • The 2' base piece was initially out of pine, but it wasn't flat enough, so I glued an oak piece, cut and sanded it down. In fact, I like that it's 2.5" thick. Th swivel idea was good on paper, but doesn't work too well, so I tighten the nut all the way.
Tae
  • Ambassador
:cheers::clapping:
FINE LOOKING WORKMANSHIP.............
