Members rccolt45 Posted June 24, 2012 Members Report Posted June 24, 2012 Hi guys, I am looking for a easy way to measure cant so I can build holster to a specific degree of angle. Mostly for my IWB what I have been doing is using a protractor on my collar templet and darwing a horizontel line I then draw another line at say the 15% mark. On that 15% degree line I put my holster for my t-nut fastners. This seems to work but I am not sure its right. I looked at what Matt Delfatti has on his sight on how to measure cant and its way different from what I do and I don't really understand it. Any help would be much apperciated. Quote
Contributing Member TwinOaks Posted June 24, 2012 Contributing Member Report Posted June 24, 2012 I use the belt line as 'horizontal', drop a perpendicular line from it, and mark the angle through the perpendicular. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members rccolt45 Posted June 24, 2012 Author Members Report Posted June 24, 2012 1340549652[/url]' post='253900']I use the belt line as 'horizontal', drop a perpendicular line from it, and mark the angle through the perpendicular. Ok cool that's what I have been doing too. Thanks Quote
Members Dwight Posted June 25, 2012 Members Report Posted June 25, 2012 (edited) I use the belt line as 'horizontal', drop a perpendicular line from it, and mark the angle through the perpendicular. Actually, when I am making a pattern that needs a certain degree cant, . . . I do the exact same thing as TwinOaks, . . . AND, . . . I slip it just a little bit off to the right hand side of middle on my paper, . . . it becomes the sewing line for the top (sight tunnel) of the weapon. Those three lines: the horizontal, the perpendicular, and the cant line, . . . are always my first three lines, . . . and when the cant line is established, . . . that is the first line on my new holster pattern. Every thing is measured and/or drawn from that cant line. That will always properly orient the weapon to the desired cant. Works every time. May God bless, Dwight Edited June 25, 2012 by Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
