Denster Posted July 5, 2012 Report Posted July 5, 2012 Ok thanks. I didn't realize there might be a break in period for this pump. The instructions were rather sketchy. I lieu of a vinyl or poly bag, I am going to experiment with a used inner tube that I picked up for free from the local tire store. I am working on an idea using pvc tubing to use as clamps/sealers on the cut ends. I also made up a vacuum hose using quick disconnect air fittings and a schrader valve fitting. Only problem I can see initially is that I won't be able to see through my homemade bag to see what needs to be molded - but I think the outline should be distinct enough. Will see how that works out. PS: Where did you get your bag and how much was it? I got it from veneer woodcrafters. It is 2'X4' which is actually enough for two bags if the first section I am using ever wears out. 2500+ holsters and still going strong. Cost was right at $100 after shipping. Quote
Members Retired LE Posted July 5, 2012 Members Report Posted July 5, 2012 I got it from veneer woodcrafters. It is 2'X4' which is actually enough for two bags if the first section I am using ever wears out. 2500+ holsters and still going strong. Cost was right at $100 after shipping. Ok thanks. I will check out the site. Mike Quote
Members Dwight Posted July 5, 2012 Members Report Posted July 5, 2012 I bought a piece of vinyl at JoAnn fabrics, . . . folded it over, . . . contact cemented the edges, . . . I roll the end & put it into a piece of 3/4" pvc that has a slot for it, . . . thread a 1/2 in rod in to hold the vacuum, . . . turn on the pump, . . . watch the vac work, . . . Bag cost: about $15. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Retired LE Posted July 6, 2012 Members Report Posted July 6, 2012 I bought a piece of vinyl at JoAnn fabrics, . . . folded it over, . . . contact cemented the edges, . . . I roll the end & put it into a piece of 3/4" pvc that has a slot for it, . . . thread a 1/2 in rod in to hold the vacuum, . . . turn on the pump, . . . watch the vac work, . . . Bag cost: about $15. May God bless, Dwight How did you attach the vacuum hose to the finished bag? Did you make your own fitting or use an existing item? Quote
Members Dwight Posted July 6, 2012 Members Report Posted July 6, 2012 How did you attach the vacuum hose to the finished bag? Did you make your own fitting or use an existing item? Retired LE, . . . I looked back at my paypal list, but could not find the supplier. I found them on Google, like I do most every thing else I need. They were a small company, . . . associated with vinyl veneer bags used in the wood veneering business, . . . and if I remember correctly, they also offered bags for sale. I only bought the bag fitting, . . . price was in the $15 to $20 dollar range, . . . Ordered it, . . . punched hole in the bag, . . . screwed it all together, . . . VOILA, . . . it worked. The bag itself is .015 thick. Hope this helps. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Dwight Posted July 6, 2012 Members Report Posted July 6, 2012 Retired LE, . . . here's another view of the fitting. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Retired LE Posted July 6, 2012 Members Report Posted July 6, 2012 I found them on Google, like I do most every thing else I need. They were a small company, . . . associated with vinyl veneer bags used in the wood veneering business, . . . and if I remember correctly, they also offered bags for sale. I only bought the bag fitting, . . . price was in the $15 to $20 dollar range, . . . May God bless, Dwight Ok thanks Dwight. My apologies to the OP (original poster) for hijacking this thread.... Quote
