Hey All,
this is gonna sound stupid, but could someone post a video of applying brown dye?..every time i try, it come out mottled looking....i can get a even coat for the love of all things holy...i usually spray on with an airbrush, and that works, but sometimes production is halted due to my air compressor sounding like a steam engine and the kiddos bed time...but i would really like to get stuff done...time is money and all. black i can do okay, anything else is a crap shoot....
thanks for all the help
Don
Havoc Holsters
Hi,
Sorry to cut into your thread, but Aaron, do you cut your dye before using it for dip-dyeing? What proportion of spirit to dye do you normally use?
Thanks!
Don - I'm with you. I hate applying dye with anything but an airbrush. Check out satansbarber on YouTube - he does most of his stuff brown, by hand.
http://www.youtube.com/watch?v=BTNJSOEwPUs&feature=youtube_gdata_player
Hi,
Thanks!
I usually dilute it. Depends on the item and the color, but about 50% is what I have been doing lately. Sometimes full strength, sometimes up to 2/3 diluted.
Aaron
From the grump: IF applying dye manually (dauber, rag, sheep's wool, etc) The best I have been able to get was with those cheap foam brushes. Dilute the dye (Fiebings dark brown is DARK!) at least 25% dye to 75% denatured alcohol. Lay the dye on in one direction, keeping the brush wet with dye, follow with a second coat at 90 degrees to that and (usually) a third coat at 45 degrees to that. That (almost always) results in an even finish, depending on how the leather wants to accept the stuff.. Mike
Edited by katsass
NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!!
At my age I find that I can live without sex..........but not without my glasses.
Being old has an advantage.......nobody expects me to do anything in a hurry.
Too funny...after I posted this I found this video..very informative,..i just wish he was doing bigger pieces...have you tried Block dyeing?...i wonder if that will work
Havoc Holsters
Hey Mike, have you ever tried using sponges?...someone here made a refernce to using small kitchen sponges and applying in small circles...i tried the foam brush, and it worked okay on smaller pieces, but still streaked where my brush overlapped...i think the dye might be suspect as well..one of the batches i cut with mineral spirits instead of denatured alcohol...
Havoc Holsters
Well, mineral spirits is oily, and IMO does some strange stuff to leather. I only use sponges to dampen my edges for burnishing - and I use my hands almost as much
With the little foam brushes, the trick is to work fast and keep the brush loaded with dye. Don't apply dye with a half dry brush. Mike
P.S. Should go without saying, allow to dry - at least 24 hours, then buff the snot out of it and apply oil.
Edited by katsass
