I've used the search engine, but I can't find a post about sharpening a diamond shaped awl blade. Any help on this topic would be appreciated.
Thanks,
John
There is a video on youtube, just search "sharpening an awl" I didn't think much of it, but it's awl I've seen. It'l get you started.
It is to the point. (Sorry for the bad puns.)
Kevin
Once believed in GOD and the DOllAR...... Hello God!
Kevin, Thanks for the quick response and I liked your pun!
John
I start out on a stone then may go wet dry sand paper and finish by buffing. Buffing wheel with green compund on a grinder works fine if you don't have a buffer.
I'm old enough to know that i don't know everything.
Thanks,
John
I found this on the web a while back.
http://www.bowstock.co.uk/saa.html
Charlie
