@Bugg, the only reason that this machine would not be great for leather flat presser foot. A flat foot machine like this one only has bottom feed. That's the same feed as virtually every domestic sewing machine. While a flat foot works fine with cloth, it drags leather and vinyl, or any bulky material. To overcome this limitation, Singer invented a so-called compound feed walking foot system. Their walking foot has triple feed, with the needle, inside foot and feed dog moving in sync as the presser foot lifts and lowers, pivoting off of the inside (alternating/vibrating) foot. Some versions of the Singer 153 have compound feed, like the 153w103 and 153k104. Unfortunately, yours isn't one of them.
So, what can you do to make this a leather sewing machine? About the only thing that may be doable is to search for a roller foot and presser bar set that will fit into your machine. I don't know the specifics of that conversion. The bar would have to be the same exact diameter as the original. But, it would have to be shorter to accomodate the longer roller foot. This was just mentioned in a toopic in the leather sewing machines forum.
If you are even able to obtain a roller foot and preser bar, you'll probably need to also find a single row feed dog and matching throat plate. This can get real tricky since Singer's industrial sewing machines has been out of business for many decades.
Posted IMHO, by Wiz
  • 3 weeks later...
Has anyone ever converted this model to a rolling foot? I have a Singer 44-30 which is a shorter bed version of a 31. I have a 153k in my area for sale and I'm wondering if I could drop the rolling foot out of the 44-30 and simply install it into the 153k.
@Wizcrafts you might be the best person who could answer this?
depends on if your local 153 is a walking foot / triple feed machine or a needle feed machine.
If it is a walking foot / triple feed then it is not possible but if it is a needle feed machine then there is a workaround then it would work but again its a workaround:
