Members TSquared Posted November 21, 2012 Author Members Report Posted November 21, 2012 Eric, I went to the two hole method. Tension is almost as stiff. I loosened the nut until I was on with one thread on the shaft. tension was looser. I tightened the nut till it was flush with the end of the stud. way too tight. the machine will sew but when you want to pull the cloth out the back (after raising the presser foot) I break the needle or the thread. I am posting another photo along with the video I uploaded on youtube. gotta get up early for work so I am cashing in for the night. Thanks, Tom http://youtu.be/GRWXwgEmHr8 I guess I can't past the youtube link here. I will try again tomorrow night. Quote
Members gottaknow Posted November 21, 2012 Members Report Posted November 21, 2012 (edited) You can also go through just one hole on the very top vertical thread guide. Make sure there are no wraps anywhere from the cone to the top thread guide. You want your thread coming right off the center of the cone, straight up to the guide hole, then down to the first guide on the top of your machine. To remove your fabric, turn the handwheel until the takeup lever reaches the top and just begins to descend. Lift your foot all the way to release the tension, pull straight back. If your tension doesn't release, check the adjustment. There's a small pin that runs through the tension post, and releases your tension when your foots lifted. I can also tell from your still pic that your feed dogs and needle bar are going to have to be adjusted towards what I call the front of the machine, where the operator sits. That should resolve your issue. Regards, Eric Edited November 21, 2012 by gottaknow Quote
Members TSquared Posted November 21, 2012 Author Members Report Posted November 21, 2012 I must have gremlins in my house. Last night when I pasted the YouTube link all I saw was a large square with a red x in the corner. Tonight I will work on adjusting the feed dog and needle bar. I also have to adjust the lift of the foot. This is where my problem is. When I lift the release lever, the foot only comes up maybe a 32nd. I saw a video on you tube where is seemed that the foot should lift 1/4 inch or more. I also noticed last night that I have a burr at the end of the needle hook. It is not in a position to stone very easily. I also noticed that there is some slop in the shaft side to side. A new bushing or bearing might be in order. Is there an easy way to get the hook out? Quote
Members gottaknow Posted November 21, 2012 Members Report Posted November 21, 2012 You can clean up the hook in the machine starting with some 400 and then some 600. Fold a small piece of the emery in half several times and place it under the hook, pulling it towards the point of the hook. Do the same on the top. Do this with the 400 until the burr is gone, then polish a bit with the 600. The play you're likely feeling is the play in the bobbin basket, not the shaft of the hook. There's a sealed bearing that shaft goes through on the top of the hook saddle. They usually have very little play in them, even on older machines. I posted a video on another thread showing this play on a two needle machine. I'll post it here so you can see if this is where your play is at. Adjusting the lift of your foot is pretty straight forward and yeah, it's not lifting near enough to activate your tension release. Regards, Eric http://youtu.be/KMx2uIrYcSE Quote
Members TSquared Posted November 21, 2012 Author Members Report Posted November 21, 2012 Gee Eric you must get up pretty early! I can't even think straight that early in the morning much less posting video. Thanks for the tip with the emery cloth. I will polish her up tonight. Thanks, Tom Quote
Members gottaknow Posted November 21, 2012 Members Report Posted November 21, 2012 Factory starts sewing at 7am. I need a few hours of coffee drinking before I walk in the door and start turning screwdrivers. Quote
Members dmar836 Posted November 21, 2012 Members Report Posted November 21, 2012 So I adjusted the opener, the needle bar again, the tension, and the hook timing in about 3 more settings. Polished the underside of the throat plate as well. Still breaking a loop but only when I am hand feeding the wheel or transitioning back and forth from motor to hand-wheeling slowly. When I felt it tighten a bit I flipped the machine up and watched on two occasions. I see exactly what is happening. The top thread loop is almost formed around the hook body and just before it can slip off the hook into a knot, it pops apart. As it breaks I can just see the needle again penetrating the bottom of the fabric for the next stitch! What is breaking is the prior stitch that has not yet formed a knot underneath. My question is how can it stitch well when going full bore or even at a controllable steady speed but then when really slow or when fed by hand the stitch hook hasn't eenough time to get fully around before the needle is coming down through the fabric again? I wonder if it is catching on the back edge of the needle guard or some other slight protrusion only when slow as when faster the thread is whipped around it without snagging? I notice it does "bump" over the bobbin bail slightly when going slow and noticed the same of the needle guard a while back. I just never see it as it happens. Otherwise It sure is odd that only one stitch in 50 to 150 stitches suddenly appears retarded. NOw it's getting interesting. Dave Quote
Members gottaknow Posted November 21, 2012 Members Report Posted November 21, 2012 Not unusual. There's a spot on the thread path that's catching as it goes around the hook. Run a finger around the entire thread path. I use 1500 grit paper to polish. Check the little screws that are in various locations on the hook. You're getting closer! Regards, Eric Quote
Members TSquared Posted November 21, 2012 Author Members Report Posted November 21, 2012 What would we do without you Eric? Quote
Members gottaknow Posted November 21, 2012 Members Report Posted November 21, 2012 I have to do something with 33 years of turning screwdrivers. Quote
