Rooster, I picked up a very nice 1/2 ton arbor press by Palmgren from Amazon for ~$60, with free shipping.
http://www.amazon.com/Palmgren-61051-2-Ton-Manual-Arbor/dp/B00068U7QS/ref=sr_1_2?ie=UTF8&qid=1352829398&sr=8-2&keywords=palmgren+arbor+press
It's a nice press that already has a 3/8" hole drilled in one end of its ram. It comes with several mandrels that fit into that hole, and it has a magnet inside to hold them in. This means that you won't have to modify the press unless you see fit. I had my machinist turn down the tools I have that are larger in diameter than 3/8" and had him make a shim to accommodate smaller ones. Many rivet setters, etc. come in 3/8" diameter, so you don't need to modify them at all. Works for me and you won't have to wait for Santa! :winkiss:
Michelle
Keep your eye out on the machines for sale forum right here. They do pop up. They are indeed heavy. I found one not too long ago here and seller did a great job in shipping to TN from CA. It was only around $200 and I had to pick up at local trucking depot where they helped me load it. I am still not sure of the brand that I have as it is not marked anywhere. BTW, the lucris bench clicker/press are still manufactured today. http://www.lucris.com/ They are a bit pricey $1K plus.
Here is a pic of the one I found. If you know the brand let me know! :o)
BTW it is not a converted arbor press.
post-13859-0-00002800-1353242079_thumb.j
Check out my blog. I posted pictures of the one that I built for my use. A converted Harbor Freight model.
Wow, thank you for the info on how to build the press. I have been planning on doing this myself and your blog will be really useful. Thanks!
Sorry guys, but I'm wanting something quite a bit larger than an arbor press. I have one of those types for pressing on buttons and rivets.
What I want is something similar to this for clicking out patterns and wet molding holsters!
