  • Replies 29
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Thought these might help someone understand a little better.
Rob
THAT Angulo has the knife inclinations?.
my first cutter was very simple and took 2 hours to make. Another one was made by an welder for me, paied 40$ for this.
crow
crow
I made one like that some time back and it works great. The wooden one. Your design is alot better than the one I made. It adjusts out farther to cut wider strips. Thank you for sharing.
Tom
Edited by carr52
Trastu,
¿La mirada a la foto original del cortador (en el comentario 9)- ve los huecos grandes? Esto es realmente 3 pedazos, con un cerrojo que lo mantiene unido. El pequeño espacio entre los pedazos, un vertical y otro en un ángulo, es donde el cuchillo es insertada. Es sostenido en el lugar por la presión de la tuerca de mariposa en el cerrojo de asamblea. El anillo es movido hacia o lejos de el cuchillo para controlar la anchura. El anillo también puede ser colocado cerca de la ranura angulada para biselar el cordón.
Al menos esto es como lo veo trabajar.
(Online translation, y'all....I ain't that good!)
Trastu,
Look at the original pic of the cutter (in post # 9) - see the big gaps? It's actually 3 pieces, with a bolt holding it together. The little space between the pieces, one vertical and the other at an angle, is where the blade is inserted. It is held in place by pressure from the wing nut on the assembly bolt. The collar is moved towards or away from the blade to control width. The collar can also be placed close to the angled slot to bevel the lace.
At least that's how I see it working.
Edited by TwinOaks
Mike DeLoach
Trastu,
Trastu,
thank you very much for the explanation. health
