Members davey bootstrap Posted December 13, 2012 Members Report Posted December 13, 2012 Hi I've just bought a singer 99k to do some wallets and stuff basically to learn on as everything I do at the moment is hand stitched I've followed the instructions on threading but it seem s to get wound up underneath any advice would be most welcome Daveybootstrap Quote
Members pcox Posted December 13, 2012 Members Report Posted December 13, 2012 seems like you do not have tension on the upper thread. Quote
Members trekster Posted December 13, 2012 Members Report Posted December 13, 2012 Be sure the thread is unwinding from the bobbin in the proper direction, and that your bobbin tension is set relatively in a neutral setting. If those things are okay, may want to check the needle is seated correctly and the scarf is in the proper direction. Last thing to check would be the timing, to be sure the shuttle hook is always picking up the thread. Quote
Moderator Wizcrafts Posted December 13, 2012 Moderator Report Posted December 13, 2012 Top thread bunching up on the underneath is almost always caused by one of these things: No tension, or too loose beehive spring tension in top thread disks Excessive spring tension on bobbin thread Bobbin thread jammed against bobbin case or shuttle race Failure to hold back the threads, or at least the top thread, as you start to sew. Quote
Members Sylvia Posted December 13, 2012 Members Report Posted December 13, 2012 (edited) Did you get an instruction booklet with your 99k? If not this PDF will help you at LEAST get the thing threaded correctly. Users Manual: http://www.sew-classic.com/uploads/99K.pdf adjuster's manual. http://parts.singerc...Manuals/99K.pdf Edited December 13, 2012 by Sylvia Quote
Members davey bootstrap Posted December 13, 2012 Author Members Report Posted December 13, 2012 hi thanks for the advice i did get threading instructions and it worked fine for 4 or5 stitches then got caught up and now it isnt picking up the bottom thread just seems to get wound round something ? Quote
Members educatedcobbler Posted December 13, 2012 Members Report Posted December 13, 2012 this sewing fault can happen due to ---- incorrect sewing tension (adjust the tension) ----needle incorrectly set in needle clamp ( reset the needle) ----incorrect threading ( re thread machine ) ----poorly lubricated thread ( use better quality thread ) ----feed dog sway ( tighten the feed dog ) ---- pressure foot bounce ( proper pressure foot ) Quote
Members Anne Bonnys Locker Posted December 16, 2012 Members Report Posted December 16, 2012 Clean it. Crap in the bottom end or tension plates will cause all sorts of nastiness. Occasionally the whole tension assembly is too far in which causes the tension to be released when you try to sew anything thicker than two layers of silk. Test this by slowly raising the presser foot and working out where the tension plates start to release. Quote
Members Sherkhan1962 Posted February 4, 2013 Members Report Posted February 4, 2013 Thanks Sylvia for the booklet links - really free PDF are often hard to find. I just bought a 185K, cosmetically refurbished model of the 99K, but the mechanism is the same. Hand shake or kiss, you chose - because I noted you won't tell your gender Quote
