Members Harag Posted April 28, 2013 Members Report Posted April 28, 2013 Thanks will take a look, never thought of Amazon for supplies Amazon - that famous book shop Quote
Members oltoot Posted April 28, 2013 Members Report Posted April 28, 2013 The more the merrier; my practice has evolved from 'old days' when we would cut out an entire saddle and throw it in a tub of hot water til there were no more air bubbles, then drip dry, then put in between sheepskins to keep and take it out a piece at a time to work but I digress. I put a piece that is fit and ready to be stamped in a tub of hot water til all the air bubbles cease, drip dry, lay it out flat on my cutting table, apply pro-carve solution 5-1 mix or Murphy's oil soap liberally to surface then let that soak in til surface is again free of puddles, place in plastic overnight to plump fibers, then lay out flat til it dries back to almost natural color then tool. If I need to add moisture- plain water from the back then cover with exposed x-ray films I got from my vet clinic till it soaks through then, if necessary, let it dry back to tool. Quote
