Members ChrisTopherloaf Posted January 5, 2013 Members Report Posted January 5, 2013 Do y'all put the holes in, then finish/dye the belt before you sew it or do you sew it, put it all together minus the hardware then dye it? Frankly, I'm afraid to dye my belt because everything I've always dyed has come out ultra stiff. I'm thinking about keeping it 'natural' color but I'm a 31 year old (in Feb.) and I wear jeans and polo/golf style shirts, button up long sleeves, and the occasional tshirt. So frankly, I'd like the belt to be tan and go with most of what I wear. So, dye it first, then sew, or sew it first then dye? Thanks!!! Chris Quote
Contributing Member rdb Posted January 5, 2013 Contributing Member Report Posted January 5, 2013 Dye after making holes but before sewing. That way the holes can be dyed too. I use Feibing's oil dyes. Spirit dyes do dry and stiffen the leather more, but a coat of oil should fix that. If you prefer it natural, clean and deglaze it first thing after cutting. Oil it.(sun dry it for a darker natural). Let it dry good. Apply finish if you aren't tooling. Let it dry good, again. That way it is clean and remains so during the build. It's easier to wipe dirt and such off from making it. When done apply second top finish. Then do the sewing, and assembly. Quote Web page Facebook
Members Dwight Posted January 5, 2013 Members Report Posted January 5, 2013 (edited) My belt process is: Cut the blanks, punch all the holes for the buckle end Rough cut the tongue end Contact cement them together Sand the edges Use the sander to finish cut the tongue end Stitch gouge Bevel all edges Sew it up Tamp down the stitches Punch the holes at the tongue end Dye the belt Dress the edges Apply finish Apply hardware Inspect for dufus mistakes The only time I dye first then sew, . . . is when my customer wants white stitching. I generally try to dissuade them, . . . but sometimes folks just want what folks want, . . . and like Jimmy Dean, . . . we just aim to please. This works for me, . . . as I usually only do a dark reddish/brown or black belts. When someone wants a "tan" one, . . . I generally give it a coat of neatsfoot oil, . . . let it dry, . . . then finish the belt. I only use Resolene on my CHL belts. May God bless, Dwight Edited January 5, 2013 by Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members ChrisTopherloaf Posted January 5, 2013 Author Members Report Posted January 5, 2013 Oh, hrmmmm. I purchased Fiebing's Light Tan leather dye for the typical veg tan hides. So just oil it...let it dry....oil it again...let it dry again and then it's good? Do you do a buff at the end at all? My stitching is a tannish brown color. Quote
