Members Feraud Posted January 22, 2013 Members Report Posted January 22, 2013 Ah, got it. Thanks for the explanation! Quote
electrathon Posted January 22, 2013 Report Posted January 22, 2013 When you seal the entire piece with your finish coat, you're stopping the antique from coloring the leather. An antique is designed to sit inside the tooling and not actually color the leather. After you antique, you finish it again to seal the antique into the tooling, otherwise you risk it wiping out with use. You can use many different finishes for a resist. The two I use are either neatlac (clearlac now) or Fiebing's Resolene. I've also been hearing a lot of good things lately about RTC Sheridan Resist, so I've been thinking about giving it a try as well. So: 1.) dye 2.) seal with finish to "resist" 3.) antique 4.) seal again to protect the antique Very good explanation Quote
Members ReneeCanady Posted January 22, 2013 Author Members Report Posted January 22, 2013 Thank you so much everyone! I guess I was under the same impression as Feraud. I couldn't get it thru my head that if I actually sealed it how the antique would get in there Quote www.facebook.com/alteredleather
Members Cyberthrasher Posted January 22, 2013 Members Report Posted January 22, 2013 Thank you so much everyone! I guess I was under the same impression as Feraud. I couldn't get it thru my head that if I actually sealed it how the antique would get in there Be sure to show us what you come up with Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members mototech7 Posted January 23, 2013 Members Report Posted January 23, 2013 i just got some rtc yesterday! i did a test run and it seems so much easier to use than resolene, what i have been using lately! Quote
