I would really appreciate feedback on the holster patterns I have attached. They are for a Bersa Thunder 380.
Many years ago I had a leather business in Montana and made a lot of custom "cowboy" six shooter hogleg holsters. I never had reason to make a holster for an automatic weapon - or even a revolver - because out there it was open carry and well, it was the west. :) Also, the holsters were custom fit to each customer's gun. I can't even tell you what type of guns they were because my patterns just have the customer name on them.
Now, after years of working a regular job to raise my family, I am getting back to doing leatherwork. I started with jewelry and bracelets, added messenger bags, purses and knife sheaths.
Recently, a friend asked me to make a holster for his new gun. He agreed to be my guinea pig since it had been so long since I had made a holster and I had never made a concealed carry holster for an automatic weapon.
So, here are the patterns I have drawn up. He is on the hefty side and thinks he would prefer no cant. I would also appreciate thoughts on that.
Finally, any thoughts on the sweat shield/hammer strap would be appreciated.
post-33806-0-39933200-1359826309_thumb.j Pattern with no cant
post-33806-0-30237600-1359826327_thumb.j Pattern with 7.5 degree cant
post-33806-0-52367100-1359826341_thumb.j Pattern with 15 degree cant
I won't comment on the cant of the design because that is totally subjective- your customer wants what he thinks he wants.
However, on the holster itself.....regardless of which pattern you use, you have some areas you need to address. First and foremost is the stitch line. It is waaay to far from the gun. Over time, the leather will stretch a bit and the gun will be loose in the holster. On the top and bottom pics, you really need to change where the holster meets the trigger guard. As drawn, both will be in the way of a good grip. They're also likely to be in the way of the mag release.
Thumbstrap is optional, but again, it's gonna depend on what the customer wants. If you're going to use one, it's easiest to just incorporate the snap in the "sweat shield".
Mike DeLoach
Thanks so much for your feedback! Now a few more questions...
I'm asking about the cant because this is my friend's first concealed carry - first holster for that matter - so he really isn't sure either. I'm not able to help because the holsters I did in Montana were all straight draw because that's what my customers wanted for their six shooters. It would be nice to know the ideas behind the variations.
Next, I'm all about getting the stitching line right so I really appreciate the feedback there! When I drew it, I measured the top of the slide which was almost 7/8" then I gave a little allowance for the leather I'm using - 8-9 oz - and measured 5/8" from the outline of the gun. Is that too much leeway for that thickness of leather? I could drop it back to 1/2" maybe?
Thanks also for the comments on the grip. I think the grip I have drawn would work for my hand but I think you are right - it may be too small for his. And I'm confused by the mag release. I've heard it shouldn't be covered by the holster but then I see holsters that definitely cover it. The mag release on the gun is very stiff and I'm thinking the thick leather I'm using probably won't easily compress it but again, never had to worry about that type of thing before so I'm definitely in learning mode.
He does want a thumbstrap and I'm still figuring out how I want to do that - hence the incomplete drawing of that portion of the holster - so thanks for the suggestion of incorporating it into the sweat shield. That was my inclination but just wasn't sure what to do there yet.
Again, thanks for the feedback and if you have anything further to share, it will definitely be appreciated. Same for comments from anyone else!
Jeannie
You place the gun slide against the stitch line on the right, as viewed, and measure 5/8 from the trigger guard side for your spacing. Right now you have twice as much as you need. Hope that makes sense. Dont forget to tape a pencil or dowel to the slide top so you can mold the sight tunnel. This way the sight does not snag as you draw the gun.
Michael
The key to immortality is first living a life worth remembering.
Bruce Lee
Thanks but, nope, I'm lost!
For my stitching lines, I thought I was following particle's suggestion. "Regarding your stitch line, you want to offset it at least 1/2 the thickness of your firearm, plus maybe another 1/16" to 1/8". This helps allow for the thickness of the leather, as well as a molded sight channel."
So the gun's thickness is 7/8". Half that would be 7/16" and I added 1/8" for the thickness of the leather (8-9 oz). So roughly 5/8" or actually 9/16" from the firearm on either side of the gun, since it is a pancake holster.
Help! What am I missing about this?
Thanks so much for commenting!
Oh, and love that dowel idea for the sights!!
What you are missing is the other measurement...you're using the measurement from only one side of the gun. The trigger guard is much thinner (actual measurement on this one at the gun store is 3/8ths inch)....so you need half of the 3/8ths + leather for the line at the trigger guard side of the gun...in this case you'll be about 5/16ths" offset at the trigger guard. However, the 'general rule' is only that..you'll likely find that after molding, you'd be able to move the stitch line in to almost the profile of the gun on the left side and be fine. And that's just my opinion of course, as I don't know how you'll be sewing it. I'd suggest making the base holster as you have it drawn and then mold down to the gun and see what the actual offset is for the leather you're using.
Mike DeLoach
Excellent point! I certainly didn't think of variation of the thickness from the slide side to the trigger side.
Okay, so that makes sense to me. I'll be handstitching so no stitching foot has to be considered in marking the stitching line. Thanks so much!!
Anything else I'm missing?
It looks cool to tip the belt slots, but this does change the length of the slots. Over time it can contribute to looseness. Straighten them out.
Tell the guy he wants at least some cant. Especially if he is overweight, he will have a very tough time reaching back and pulling straight up.
Thanks so much! I wondered if leaving it straight might cause issues for him drawing the weapon since it's not hanging down from the belt as hoglegs do.
I read in my research that the slanted belt slots would help pull the barrel toward the body but others said that it didn't make a big enough difference to worry about. Good to know they can get loose over time that way. I'll straighten them.
I'm really appreciating all the good pointers!
Forget everything I said except the part about the dowel. I'm not sure what I was trying to say. I was asleep I think. Sorry
Michael
Bruce Lee
