Members ElectricHellfire Posted August 22, 2008 Members Report Posted August 22, 2008 Ok, Ive been doing sheaths and holsters for about 5 years now and recently Ive switched from a 4 prong punch to using a smooth scratch awl blade mounted in my drill press for making stitching holes. I get a much improved more uniform hole this way and its easier to go through multiple layers in one pass. I went to my local Tandy today to get some replacment blades and they dont have any. All they carry are the flattened ones so I had to purchase a whole new kit for $25. The kit has a grip with 4 different blades int it. My question is, what do you guys/gals use to punch your holes with. Does anyone know where to find smooth, round awl blades?? Can you use a large needle of some kind? Thanks Quote
Members DCKNIVES Posted August 22, 2008 Members Report Posted August 22, 2008 Ok, this is what I do.I also do sheaths and holsters primarily.I sharpen the shank end of various size drill bits and chuck them upside down.Very smooth and little flex. I also do alot of lacing, hence the reason for multiple sizes. A 1/16" should be good for standard thread.It will help you to cut up some wood and notch it for belt loops, as it makes for a very flat surface to punch into.Dave here's my setup Quote http://dcknivesandle...lademakers.com/
Members strapt Posted August 23, 2008 Members Report Posted August 23, 2008 I punch my holes for stitching most of the time. (I know, that's not the proper way to saddle stitch.....) I use a home-made awl that is merely a nail cut (or ground) flat on one end and glued into about a 1"d dowel for a handle. The exposed end of the nail is then put to a grinder to get a nice tapered point. The advantage to the dowel is that it is flat on the opposite end, so I can hit it with my mallet. I lay out my holes with a stitch wheel, grab the homemade awl and a my mallet and knock the holes in. Piece of cake, and no drill press. I'm too busy using the drill press to slick edges afterall. Quote
