Contributing Member SooperJake Posted February 23, 2013 Contributing Member Report Posted February 23, 2013 What should I adjust when the knots are visible from the bottom? I sometimes have to switch between the flat plate and the holster plate and when using the holster plate, it seems the knots show up more often. Quote Once you know what the magician know.... it isn't magic anymore.
Moderator Wizcrafts Posted February 23, 2013 Moderator Report Posted February 23, 2013 Less bottom tension, more top tension, or a larger needle size. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member SooperJake Posted February 23, 2013 Author Contributing Member Report Posted February 23, 2013 Less bottom tension, more top tension, or a larger needle size. Thanks Wiz Quote Once you know what the magician know.... it isn't magic anymore.
Members Rayban Posted February 23, 2013 Members Report Posted February 23, 2013 (edited) I was getting those when I forgot to give the thread one full wrap around the second (btm) tension wheel. ( I have the 3500) I thought I could thread the machine in my sleep, guess I can't yet. Edited February 23, 2013 by Rayban Quote Raybanwww.rgleather.net
Contributing Member SooperJake Posted February 23, 2013 Author Contributing Member Report Posted February 23, 2013 (edited) I was getting those when I forgot to give the thread one full wrap around the second (btm) tension wheel. ( I have the 3500) I thought I could thread the machine in my sleep, guess I can't yet. One and a half actually, on the 4500. Not sure about the 3500. Edited February 23, 2013 by SooperJake Quote Once you know what the magician know.... it isn't magic anymore.
Moderator Wizcrafts Posted February 23, 2013 Moderator Report Posted February 23, 2013 I'm currently using two turns around the bottom disks. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Rayban Posted February 23, 2013 Members Report Posted February 23, 2013 One and a half actually That was my problem, I never counted Quote Raybanwww.rgleather.net
Moderator Wizcrafts Posted February 23, 2013 Moderator Report Posted February 23, 2013 I feed the thread down, through the steel loop guide over the bottom disks, then around the disks twice, then back up through the guide, then to the thread check spring, etc. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
