Cant figure out what is going on, machine was running fine, now every other stitch or almost every other stitch you can see the top thread on the bottom. Hope that makes sense. I dont think it can be a tension issue, but i dont know for sure. the springy eyelet thing seems to make a loud click sound, not sure if its normal or if its part of the problem, once something goes wrong every little noise seems out of the ordinary and its hard to remember if it made that sound before haha.
I would start at the spool and work my way down. Sounds like your thread is hanging up somewhere. Is the spool directly under the arm so it pulls the thread straight up off the spool? Also check all along the thread to see if it jumped out of the guides along the way. One of these issues is usually what causes the same sound and effect on mine............just my 2 cents worth
Mike
Emergency Room Nurse by profession.......Leatherworker at heart!!
Hoping to reverse the order in that one of these days!!
I agree with Mike. I learned in my years running commercial embroidery machines...always start with the simple things like needles and thread path. Take the thread out and re-thread it. It is amazing how something so simple can cause you the most headaches.
Christine Mantz
www.tacktemplates.com
Specializing in acrylic templates for tack makers  **TACK SETS - HALTER SETS - SPECIALTY - DELRIN STAMPS**
We also offer custom acrylic templates and laser service on leather blanks
It's the black thread acting like a spring!
Posted IMHO, by Wiz
Hi jlaudio29. What size thread are you using on top and in the bobbin, what size needle, and what is the thichness that you are sewing? Steve
Thank You
Steve Tayrien
Leather Machine Co., Inc.
2141 E. Philadelphia St. Unit "U"
Ontario, California 91761
1-866-962-9880
http://www.leathermachineco.com
cobra@leathermachineco.com
Mine was doing that, a friend told me to take the bobbin and shuttle out and clean all the gunk that had built up inside there, cleaned it out, worked like a champ.
