Members lowlife Posted April 10, 2013 Members Report Posted April 10, 2013 For the guys that make them how much length do you need to add for such a heavy weight belt or do add anything kehl Quote
Members Alamo Posted April 10, 2013 Members Report Posted April 10, 2013 Well, if you're going to go the double layer belt route, I like to add just a little to the length to the center hole, about an inch. I measure from the fold over where the buckle is and that seems to do just fine, can accommodate regular buckles and trophy buckles. Quote
Members lowlife Posted April 10, 2013 Author Members Report Posted April 10, 2013 Yes I am talking about a double layer being around the 14-16 oz neighborhood. Sorry for not stating that Quote
Members Alamo Posted April 10, 2013 Members Report Posted April 10, 2013 Try adding an inch to the length and see if that works well for you. Depending on many things, you may need to tweak the added length a bit to fit your needs Quote
Members Dwight Posted April 10, 2013 Members Report Posted April 10, 2013 Go to my website, . . . go to the belt page, . . . diagram there will give you the best way I have found to measure a belt for a customer. (actually, . . . the customer does the measuring, . . . so if it is off, . . . you are not on the hook for bad measuring) I look at the "client" or at least at the weapon size, hoster design, IWB vs OWB, and I'll add anywhere from 1 to 3 inches depending on the factors I see that make it a requirement. May God bless, Dwight Quote
