Leela Valley Leather Posted April 19, 2013 Report Posted April 19, 2013 (edited) Hello folks, I've read in several different threads that some members here use an Oxalic Acid solution for cleaning or bleaching leather from time to time. While sourcing the acid is not great struggle I do have a question regarding it's use. What is the concentration commonly used on leather? I can get the acid in 100% pure form (according to the container at any rare) as crystals. Considering it is advertised for cleaning mould from bricks, paving and drive ways I highly doubt the dilution indicated on the container will do anything but destroy the leather. So... just how weak/strong does it need to be? Thanks in advance! EDIT: found this thread http://leatherworker.net/forum/index.php?showtopic=25558 and while it gives concentrations, I could not find any reference to neutralising the acid after. Edited April 19, 2013 by Leela Valley Leather Quote
Chief31794 Posted April 19, 2013 Report Posted April 19, 2013 I mix it 1 tsp to a pint of water, others may use different concentrations. It isn't an exact science, if it doesn't clean quite well enough, add a little more crystals, if it seems too strong add a little more water. I use distilled water in all my shop operations, that prevents any other trace elements from affecting the cleaner. Chief Quote "Life's too short to carry ugly leather"
Members cem Posted April 20, 2013 Members Report Posted April 20, 2013 I mix it 1 tsp to a pint of water, others may use different concentrations. It isn't an exact science, if it doesn't clean quite well enough, add a little more crystals, if it seems too strong add a little more water. I use distilled water in all my shop operations, that prevents any other trace elements from affecting the cleaner. Chief This is what I do as well, with one more step after the leather has dried I give it another wipe down with a damp cloth of just distilled water. Clair Quote
Northmount Posted April 20, 2013 Report Posted April 20, 2013 At these low concentrations, the leather basically neutralizes the acid. You can rinse off if you wish. Chief's mix works well. Tom Quote
Members Harag Posted April 25, 2013 Members Report Posted April 25, 2013 I'm just reading the "Leatherwork Manual" by Al Stohlman - in there it says 1pint of warm water to 1 tsp of acid. I've not tried it yet but I guess this is the about the right mix Quote
