Members Tobeymcmullen Posted May 3, 2013 Members Report Posted May 3, 2013 I do not own this image it was borrowed from ETSY.COM ..... I am looking for a pattern to make a resemblance of this. I have this special requested and have no clue where to start... any help would be great. Quote
dirtclod Posted May 4, 2013 Report Posted May 4, 2013 I've never made armor. But i would get some poster board and start fitting to your model, you will need to leave a tail on the patterns so you can sew / rivet one piece to the next. It may take a couple of tries to get things right, but in the end you of made your own pattern of your own design. Go for it !!! Quote I'm old enough to know that i don't know everything.
Members Paulr Posted May 4, 2013 Members Report Posted May 4, 2013 a common way to attach them together is to run a few strips of thinner leather (or flat nylon belt ) on the underside. Its riveted to the leather underneath the overlap so you cant really see the rivets. It keeps it more flexible then if you rivet the pieces together. http://leatherworker.net/forum/index.php?showtopic=16175 its a different design but it shows the straps on the underside. You would just make the strips longer and continue them from one piece to the next. Quote
Members Dwight Posted May 4, 2013 Members Report Posted May 4, 2013 I've only made one set of armor, . . . imitating the Roman stuff around the time of Jesus, . . . this is how I did the shoulders, . . . and it worked real good. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Tobeymcmullen Posted May 4, 2013 Author Members Report Posted May 4, 2013 I appreciate all the responses. I was thinking the strap down the middle made perfect sense, just wondered if leather would be the best idea with it being next to the skin. Sweat plays hell on leather. I like the design Dwight has...That will be more than likely the way I go...Thank you all. Now to play with design and development... Guess once I make one, I hope someone else wants one. Quote
Members Dwight Posted May 4, 2013 Members Report Posted May 4, 2013 If you have a Tandy store nearby, . . . ask for their bag liner material. It is used to stiffen hand bags. I use it often for patterns, . . . and to mimic leather. AND cutting it up is a whole lot cheaper than cutting up veggie tanned cowhide. Also, . . . while the strap idea is good, . . . cloth flexes a lot more than leather generally, . . . it would depend on how "flippy-floppy" you want it to be. When I did my armor, it was for one of my other personas: that of Salvatorus Antonio, . . . the Centurion of Capernaum, . . . 6th Legion, Ferata, . . . 39 AD. I did not want the shoulder plates shifting, . . . that is the reason for the "T" plates. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members DLC Posted May 22, 2013 Members Report Posted May 22, 2013 If you are still looking I have a pattern for a very similar pauldron. Quote
Members Harag Posted May 23, 2013 Members Report Posted May 23, 2013 On 5/22/2013 at 11:25 PM, DLC said: If you are still looking I have a pattern for a very similar pauldron. I would love to have this pattern, can you please send me it? Quote
Members Tobeymcmullen Posted May 23, 2013 Author Members Report Posted May 23, 2013 I would love a copy..At least it would give me a starting point.... I can send you my email address if you need it Quote
Members mrdabeetle Posted May 23, 2013 Members Report Posted May 23, 2013 I have a pattern here for spaulders. http://1of1designs.net/Spaulders1.pdf http://1of1designs.net/Spaulders2.pdf It isn't done yet, but it should be easy to figure out based on the pattern. Quote
Members Harag Posted May 24, 2013 Members Report Posted May 24, 2013 On 5/23/2013 at 9:15 PM, mrdabeetle said: I have a pattern here for spaulders. http://1of1designs.net/Spaulders1.pdf http://1of1designs.net/Spaulders2.pdf It isn't done yet, but it should be easy to figure out based on the pattern. Thanks, but having problems with the links: Oops! Google Chrome could not connect to 1of1designs.net Quote
Members mrdabeetle Posted May 26, 2013 Members Report Posted May 26, 2013 On 5/24/2013 at 4:19 PM, Harag said: Thanks, but having problems with the links: Oops! Google Chrome could not connect to 1of1designs.net try it in a different browser. I don't think chrome likes capital characters in the url Quote
Members Harag Posted May 26, 2013 Members Report Posted May 26, 2013 On 5/26/2013 at 9:40 AM, mrdabeetle said: try it in a different browser. I don't think chrome likes capital characters in the url Nope, tried Chrome, FF and even IE - all having trouble getting to the domain: http://1of1designs.net/ Quote
Members DLC Posted August 4, 2013 Members Report Posted August 4, 2013 I finally scanned my pattern, sorry that it took so long. If you use these, download them and print them out full-size. If your printer tells you that the image will exceed the paper size just ignore it and continue rather than resizing to fit the paper. I could only fit half of the largest piece on the scanner, but it is symmetric so just print another, flip it, and tape them together. Rivet holes are also marked on the pattern. I made this to attach to a breast plate so there is no shoulder strap, but I'd imagine it would be easy enough to alter it a bit for your needs. Also attaching finished pics for reference. Cheers. http://i1068.photobu...ldron/00011.jpg http://i1068.photobu...ldron/00012.jpg http://i1068.photobu...ldron/00013.jpg http://i1068.photobu...ldron/00014.jpg Quote
Members Jakrae Posted October 25, 2015 Members Report Posted October 25, 2015 Thank you DLC! This helped a lot with my first piece. I'm making some alterations, but thanks for the boost in the right direction! Quote
Members Squirrelly66 Posted October 28, 2015 Members Report Posted October 28, 2015 nice design DLC. Quote He Who Laughs Last.......Wins
Members SirNanigans Posted October 28, 2015 Members Report Posted October 28, 2015 On 5/4/2013 at 12:14 PM, Tobeymcmullen said: I appreciate all the responses. I was thinking the strap down the middle made perfect sense, just wondered if leather would be the best idea with it being next to the skin. Sweat plays hell on leather. I like the design Dwight has...That will be more than likely the way I go...Thank you all. Now to play with design and development... Guess once I make one, I hope someone else wants one. Others have mentioned the strap underneath idea, and I second that. I made similar pauldrons with hardened leather riveted together to pivot and it took me two days to do the math for the rivet placement and piece dimensions (if the pieces can slip past eachother they will look sloppy and uneven). As for the lining/smell, just line the straps and the plate that hold to your chest. Everything else won't touch the skin much. I actually lined mine with vehicle headliner fabric and pig suede (yes, more leather). The pig suede doesn't smell awful, buy has taken on 'human' odor. Then again, I wear mine shirtless so I don't sweat much. You may have a different experience if you are fully garbed. Quote
Members RobC01 Posted December 6, 2017 Members Report Posted December 6, 2017 On 10/28/2015 at 7:47 PM, SirNanigans said: Others have mentioned the strap underneath idea, and I second that. I made similar pauldrons with hardened leather riveted together to pivot and it took me two days to do the math for the rivet placement and piece dimensions (if the pieces can slip past eachother they will look sloppy and uneven). As for the lining/smell, just line the straps and the plate that hold to your chest. Everything else won't touch the skin much. I actually lined mine with vehicle headliner fabric and pig suede (yes, more leather). The pig suede doesn't smell awful, buy has taken on 'human' odor. Then again, I wear mine shirtless so I don't sweat much. You may have a different experience if you are fully garbed. Expand Old thread, but do you happen to have a pattern in PDF? Quote
Members Nightk Posted April 12, 2019 Members Report Posted April 12, 2019 Sorry for reviving an old thread but I have a question for DLC about his pattern. Do you have a strap on peice one where the pyramid studs are or is it just left as is? Quote
