I know I am probably buying into snake oil here but I was hoping someone would have a source for the type of rivets mentioned in the video on rivets in this link and a way of setting them by hand without an arbor press.
Also there is mention of thicker polyester thread in the same link. I can only find thin thread for cloth sewing that specifically mentions polyester as the material. Any sources? Thanks everyone.
http://www.saddlebackleather.com/Quality-Built-to-Last
Edited by earlthegoat2
I'm sure he's talking about solid copper rivets. You can buy a tool that pushes the washers down, cut the post down to about 1/8 or so and then use a ball peen hammer. I use a short one (6") from Harbor Freight to round off the post. You can get these at Springfield Leather or Tandy, etc. They are great - if copper is your thing and it goes with your project.
Edited by Spence
Spence
Mendoza, TX, USA
  • 3 months later...
I use these rivets almost exclusively.
I get mine at a local saddlers, but have also bought online.
They are about $35-$45 per lb. they are in various guages, from super heavy say 5mm diamter shaft to 2mm.
They look beautiful when set.
Tony
post-44268-0-36232600-1377679527_thumb.j
i felt like I had been doing everything wrong before I Started using the copper rivets. Looking back on some of my first projects that I used the little flimsy Tandy rivets, I truly don't know if they are still holding up. The copper rivets do cost a little more, but they add structural integrity to any project, and that is a great selling point for a lot of people.
As far as heavy duty thread goes, you can check out http://weaverleather.com/default.aspx
I am sure there are many different suppliers of good thread but Weaver has a great selection.
Also, check this link http://www.tippmannindustrial.com/needleandthread.php for helpful info on thread sizes and needle sizes.
Edited by jessebeckham
