  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
I have fitted the harness foot to the 205-6 adler. I am still having problems sewing. the top thread is breaking and its not feeding at times. if I got forward 3 stiches, reverse then start sewing it refuses to feed and the needle just goes up and down. im using 12 poly cotton with a 200/25 needle. i tried to make a pouch out of bridle leather this afternoon combined thickness of about 5mm and it trashed it. its been to adler and was serviced. getting sick of paying people and they don't fix it.
Your photo is blurry, so I can't see the details on your needle. Make sure that the ribbed side faces due-left and the cut-out scarf faces due-right. Watch the needle as it goes down and ascends. After rising between 1/8 and 3/16 inch, the hook should meet the scarf, about 1/8" above the eye, with the direction/feed lever in the zero position (Trox has posted the exact dimensions in metric. Search this forum). Then check in the full reverse position to see if the hook is still above the eye. Marginally timed machines may sew fine in forward, but allow the hook to clip the thread at the top of the eye in reverse. It happens to me sometimes and I reset the timing on the needle bar.
Even solidly secured needle bars can move up due to the extreme shock they endure when sewing hard leather. This throws the timing off.
Another thing to check for is the lateral clearance between the hook and the needle. Some big Adler machines use a little numbered spacer with two screw holes to place the needle the best distance from the needle, for a given size needle (default is #200). If your needle is a #200, but the spacer is the wrong number, say a #180 or #160, contact will be made between the hook and needle.
GottaKnow Eric has given good advice in his replies to remove the throat plate and watch the loop form and see what actually happens when the hook meets it. If the loop disappears, reduce the travel of the check spring. If it twists forward or backward, consider using a different spool of thread. If the loop is way too small to be picked up, try going down one needle size.
Another thing is the type of thread you are using. Poly-cotton is really made to be used in heavy duty domestic or quilting machines, as a top stitch thread. It is very soft, compared to bonded nylon or bonded polyester that leather workers normally use. These machines are capable of treating cotton thread with kid gloves. Your big Adler is not built to pussy foot around with soft thread. Also, your thread may have been wound with a right hand twist, which is the opposite of what your machine requires.
Harness shops often use needle and awl stitchers that sew with glazed, left twist, linen thread, run through a liquid wax of some kind. The wax adds body and lubrication to the thread as you are sewing, then hardens to secure the stitches in place. Linen and cotton thread are related!
Posted IMHO, by Wiz
the reason I went poly cotton because it seemed softer and when i sewed on a friends k6 it didn't fray/break as easy. I don't really understand a lot that you said because i don't know a lot about machines. the reason I paid adler was for them to get it to work. im not sure what the problem with unless the foot is not suitable. the only thing I could see being a problem is maybe the foot is putting too much pressure down and the feed is having a hard time. theres plenty of tention on the bobbin and top thread. would you suggest trying some nylon bonded? 277 is what they do saddle skirts and tack with isn't it?
Hello Avimeso, sorry for late replay. I see you have fitted the harness foot, and now your machine will not sew. I do not think thats related to the foot in anyway. However, we must find its last working configuration.
Did your machine sew before you changed thread and foot? You are telling it has been to service in a Dürkopp Adler workshop, I assume it worked as it should when you got it back? I also assumes this is a new machine to you? If I am right about this it could be a minor fault. This is a straight forward and simple machine, not much that could go wrong.
Anyway, put the roller foot back and check your threading.
This machine threads just like any other Adler 205 or 204 machines, you can download a manual on a similar class like the 205-370 and check that you have threaded your machine right http://www.duerkopp-adler.com/en/main/Support/downloads/index.html?action=search&prop0=%2Fcommons%2Fdownload%2Fpublic%2F205-370%2F&prop1=
Or check the youtube video of the Cobra 4 or Cowboy 441 clone machines that threads the same way
Make sure you use a new right size needle and if its pushed all the way up in the needle bar. And if its turned the right way (needle scarf to the right). The thread has to be left twisted, for the size tkt 12 you can use from 180 to 200 Nm needle size. I use mostly polyester threads, but I see no reason yours should not work as long as its left twisted.
If all above is Ok and it still will not sew you must check the hook needle timing. But first check all the above and post back to me.
Good luck
Tor
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Unless my eyes deceived me, I did not see you hold back the threads as you started to sew the test strip of leather. You must hold back at least the top thread, if not both. Failure to hold back the thread causes too much top thread to get pulled underneath and it bunches up under the leather and sometimes around the shuttle race. When the thread bunches up under the leather, the teeth can't move it against the tension of the bunched up threads.
Posted IMHO, by Wiz
As well as Wiz mentioned why are you stitching forward back then forward again? The machine seems and sounds to be working just start by reversing then go forward and at the end reverse to lock your stitches, if your machine can do this as it seems it can in the video then it's working, you are sewing leather not webbing or cloth.
Wiz is right, you must hold your thread tight with your left hand when you start sewing or you get a backlash.
Tor
Hi,
(I will repeat the above posts, so you understand the importance of it.)
Do not let the foot stay down on the feed dog without material under it (second video), you wear out your feed dog. Your machine looks fine to me, we are talking about some minor operating errors here.
Every time you start sewing hold down the thread for about 5 stitches, and when you are locking the stitches by sewing over them also. This is very important. If you keep on sewing like that the thread will bunch up in the shuttle house and you will knock the machine off timing. You start the seam by sewing two stitches in reverse and lock the stitches by sewing over them (or turn the work piece around). At the end of the seam you do the same thing but maybe more than two stitches. (or finishing your seam by hand, search the forum for technique). Remember to hold down the thread (both threads) when starting and finishing the seam.
Good luck.
Tor
Tor
