I need to find a tool that will turn flat leather strap into round leather straps for cores. Any advice? I've used my edgers, but it doesn't get it perfectly round.
Try putting a sharp round punch in a vise and then pull a strap of heavy leather through it, and you will end up with a round string
"The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
  • 1 month later...
the old time reata braiders used a hardwood plank with various hole sizes drilled in it and pulled materiael through from largest to smallest.
Thought it reminded me of something from woodworking. Would something like this work?
http://www.axminster.co.uk/sessionID/JPW/p...lates-20396.htm
Used for making doweling. Shouldn't be to hard to make. Next time I go to Axminster I'll have a look at it.
Make your own. There's a "how to" in one of the Stohlman books "The Art of Making Leather Cases II"
Hilly
  • 2 weeks later...
I made a tool for rounding braided stuff out of an old pipe flairing tool. jusst had to file down the grooves. they have graduated holes.
I wonder if a flaring tool for copper tubing might work.
Tom
  • Ambassador
CARR.. THE PIPE FLARING TOOL WILL WORK WELL. I USED ONE FOR A LONG TIME
UNTILL I FOUND MY OSBOURNE THAT I USE NOW.
BE SURE TO POLISH THE HOLES WELL. I HAD TO ON THE ONE THAT I HAD.
Luke
Another possibility might be jewellers Draw plates. Some examples here
They are used for reducing the diameter of wire. The only issue would be there are probably far more holes than would be required, however the D shaped and Square hole plates might produce some interesting effects.
I made a hardwood drawplate for finishing some round chains made using various techniques as it maintains the shape of the wire whereas a metal plate would eventually flatten the outer surface of the wire.
Stay safe, Stay well, Dream well.
Merrik
