Members jessebeckham Posted June 6, 2013 Author Members Report Posted June 6, 2013 Great advice everyone. I'm going to look into the MPB. Do you simply use it in place of super sheen? Also, when you apply neatsfoot, then a dye, does that not affect the application of the dye... I'm thinking Eco-pro water stains... Oil and water you know. Thanks! Gel antiques too... Quote
Members Cyberthrasher Posted June 6, 2013 Members Report Posted June 6, 2013 First off, I would NEVER use a water based dye on a product meant to be used outdoors. That said, the oil goes inside the leather - where there's already natural oils present. Second, MPB is a "Temporary" finish. Technically it can be applied by itself as a standalone finish, but it won't offer that much protection. It will help the water bead off, but that's about it. If you must use Super Sheen (I'd recommend not in my personal experience), apply it first and then put the "Temporary finish" of choice on afterward. MPB and other similar conditioners are maintenance products that should be used at the very end of construction - before packaging it up to deliver, and then every now and then by the customer for continuous maintenance. One thing you will find with MPB, and possibly other similar conditioners that I haven't tried, is that you will want to leave it over night when it's applied over a sealing finish (like sheens/lacs/resolene) so that the oils have time to penetrate the sealant. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members TomG Posted June 6, 2013 Members Report Posted June 6, 2013 I use 50/50 Resolene on most of my dog collars. I also use a thick mink oil paste applied lightly to the back side the night before applying the Resolene. I think it's the Kiwi brand. Some of the oils and thin pastes are too easily applied too heavily and can darken the finish. I have also used Saddle-Lac at a final top coat instead of the Res. It seems to hold up well also... BUT I found that if I applied it first and then applied the mink oil paste to the back, the Saddle-Lac flacked off easily the next morning. Probably something to do with not letting one or the other fully cure. I will say this about the mink oil paste. I apply a light coat, then wrap a rag around the collar and pull it in a curving motion through my hand. It softens that strap up like a noodle most times! Anyone else have experience with oil and Saddle-Lac? Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Harag Posted June 7, 2013 Members Report Posted June 7, 2013 Hi I'm about to make my first couple of dog collars this weekend and have the following Neatfoot oil Resolene (50/50) Carnauba Cream Mink Oil the leather is veg tan, and will be died with OIL dye and then have some acrylic paint on it. From a couple of tests I've found that before I put the acrylic paint on the oil I need to apply resolene so... Dye Add Carn Cream Add resolene Paint Accrylic Add Resolene My In my test I painted on the dye then added the cream, but this pulled off the paint (even after it's dried for several days) So I was wondering if anyone has any suggestion on when to add the Neatsfoot oil and the Mink Oil Many thanks Quote
Members Cyberthrasher Posted June 10, 2013 Members Report Posted June 10, 2013 Why are we using Carnauba cream before finish and paint? All that's going to do is prevent your acrylic products from properly adhering to the leather. Remember, this is a FINAL FINISH product meant for maintenance - THE ONLY CONDITIONER TO USE BEFORE SEALING IS NEATSFOOT OIL. Any other conditioning product should be used LAST before sending it out the door. tool oil (neatsfoot - not mink or any other conditioner) dye resolene conditioner Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Harag Posted June 10, 2013 Members Report Posted June 10, 2013 Why are we using Carnauba cream before finish and paint? All that's going to do is prevent your acrylic products from properly adhering to the leather. Remember, this is a FINAL FINISH product meant for maintenance - THE ONLY CONDITIONER TO USE BEFORE SEALING IS NEATSFOOT OIL. Any other conditioning product should be used LAST before sending it out the door. tool oil (neatsfoot - not mink or any other conditioner) dye resolene conditioner Thanks for pointing out the Carnauba cream & acrylic paints, not exactly sure what the cream does, but from videos I've seen the person uses the cream then resolene to finish, but you seem to be saying to put the cream over the resolene. Do I also put the mink oil on over the cream? Quote
Members Cyberthrasher Posted June 10, 2013 Members Report Posted June 10, 2013 Do I also put the mink oil on over the cream? You don't need to use mink oil if you're already conditioning your piece with the cream. They are BOTH conditioners. Over-conditioning can/will cause premature rot by breaking down the fibers. Resolene = water/UV resistant acrylic SEALER - MUST be able to adhere to the leather, not a wax coating on top of the leather Wax and oil based conditioners = May be labeled as a "finish" - they are just a temporary "polish" to be used at the end of your assembly. They offer water resistance as well as oils to condition the leather Now, think about the process you've laid out previously: Oil (with neatsfoot) Seal with water/uv resistant acrylic paint with acrylic seal with water/uv resistant acrylic condition with water resistant wax based oil conditioner (carnauba cream - not sure if it actually has oil in it) oil with mink oil Now, count how many times you're oiling here, as well as adding water resistance. preferred method: lightly oil with neatsfoot oil (lightly condition fibers) dye seal with acrylic resolene (protect dye and add water/UV resistance) condition with wax based conditioner (ONCE - to add a wax coating for further water resistance and polish things up for the end customer) send out door Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Harag Posted June 10, 2013 Members Report Posted June 10, 2013 You don't need to use mink oil if you're already conditioning your piece with the cream. They are BOTH conditioners. Over-conditioning can/will cause premature rot by breaking down the fibers. Resolene = water/UV resistant acrylic SEALER - MUST be able to adhere to the leather, not a wax coating on top of the leather Wax and oil based conditioners = May be labeled as a "finish" - they are just a temporary "polish" to be used at the end of your assembly. They offer water resistance as well as oils to condition the leather Now, think about the process you've laid out previously: Oil (with neatsfoot) Seal with water/uv resistant acrylic paint with acrylic seal with water/uv resistant acrylic condition with water resistant wax based oil conditioner (carnauba cream - not sure if it actually has oil in it) oil with mink oil Now, count how many times you're oiling here, as well as adding water resistance. preferred method: lightly oil with neatsfoot oil (lightly condition fibers) dye seal with acrylic resolene (protect dye and add water/UV resistance) condition with wax based conditioner (ONCE - to add a wax coating for further water resistance and polish things up for the end customer) send out door Thanks Cyber, you have really cleared things up, I was wondering why so many conditioners etc. Slight amend to the list: lightly oil with neatsfoot oil (lightly condition fibers) dye seal with acrylic resolene (protect dye and add water/UV resistance) >> Paint Arcylic on top of dye. e.g. dog name in white. >> seal the above paint with acrylic resolene (protect dye and add water/UV resistance) condition with wax based conditioner (ONCE - to add a wax coating for further water resistance and polish things up for the end customer) send out door Now the next question. I have both Mink oil & Canauba Cream, I've read that mink oil will be better for water "proofing" (better water resist than resolene), so I'm guessing for outdoor items like dog collars / knife sheaths etc, then use mink oil, for indoor items use the canauba cream. Is this logic about right? Quote
Members Cyberthrasher Posted June 10, 2013 Members Report Posted June 10, 2013 I've never used pure Mink oil. I do use Montana Pitch Blend which contains it though. That's what I put on every item that leaves my shop. Experiment with your order of applying acrylic paint. You may find that putting Resolene on top of it will reactivate and cause a mess. I didn't use acrylic paints for a long time, partly because of that. I was recently taught to use varnish on top of the acrylic paint and before the resolene to separate the two. So far I've had awesome results with it. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Harag Posted June 10, 2013 Members Report Posted June 10, 2013 Oh, great, thanks for the tip about the varnish, not hear of that one before. I'll have a play around with the acrylics and resolene and see what happens. I don't think we can get the Montana Pitch Blend here in the UK hence the reason why I got the Mink Oil. I take it by your post you simply don't use the Canauba cream at all. You should have a web site with all the tips & tricks, Your very helpful and have a lot of knowledge, thanks for sharing. Quote
