Members coop Posted December 16, 2013 Members Report Posted December 16, 2013 I will start oiling the leather before dying. I am also using a better quality leather now also. Once the finish is applied how can you keep the leather conditioned? Quote
Members Ski Posted December 16, 2013 Members Report Posted December 16, 2013 I always bend the leather while its wet, before I dye. Resolene (aka super sheen?) is like plastic to me, and does not like to be bent to excess. As mentioned above, I then apply carnauba crème, neatsfoot oil, and if needed seal it with resolene. Hope this helps Quote Warm regards, Mark Skiba
Members Cyberthrasher Posted December 16, 2013 Members Report Posted December 16, 2013 Resolene (aka super sheen?) is like plastic to me, and does not like to be bent to excess. As mentioned above, I then apply carnauba crème, neatsfoot oil, and if needed seal it with resolene. Hope this helps Resolene and Super Sheen are NOT the same product. Super Sheen is an attempt at copying Resolene, but should never be classified as the same. But, it is true that if you apply Resolene wrong it will come out like plastic and crack under stress. ALWAYS apply it 50/50 with water and use several LIGHT coats to build up your coverage. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Ski Posted December 16, 2013 Members Report Posted December 16, 2013 Yes Cyberthrasher that's what I do. No idea about super sheen never used it but I hear its very similar, hence why I mentioned it may be the cause of the cracks in above picture. Quote Warm regards, Mark Skiba
Members coop Posted December 16, 2013 Members Report Posted December 16, 2013 I've been using the Super Sheen with no issues so far and use light coats. I have wondered about the Resolene but I had heard some horror stories about that also. I'm thinking it was just some really dried out leather and I haven't been in the habit of oiling my leather before finishing. The cracks were deep and not just in the finish. Lesson learned on keeping the leather hydrated. Quote
Chief31794 Posted December 16, 2013 Report Posted December 16, 2013 There are many finishes on the market and IMO Super Sheen is the next to the last one on the list. I like Clear Lac best, Resolene (Cut 50/50 with distilled water) next, Angelus High Gloss (isn't really high gloss), TanKote (Cut 50/50 with Distilled Water), Fiebings Aussie if weather protection is an issue. The worst product I've tried is Saddle Lac and then comes super sheen from tandy just a little ahead of Saddle Lac. Just my opinion, I'm sure others have their favorites. Chief Quote "Life's too short to carry ugly leather"
Members Cyberthrasher Posted December 16, 2013 Members Report Posted December 16, 2013 Just my opinion, I'm sure others have their favorites. Chief I haven't tried Angelus, but mine are Resolene, Clear-Lac, RTC Sheridan Resist, then Tan-Kote. I'm slowing trying to build up to using more Clear-Lac. My first experience with it was a disaster because I didn't know what I was doing. It kind of scarred me a little. That said, I saved my first ever bottle of Super Sheen. I use it when I'm teaching someone how to do stuff. It's gotta be good for something. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members TomG Posted December 16, 2013 Members Report Posted December 16, 2013 There are many finishes on the market and IMO Super Sheen is the next to the last one on the list. I like Clear Lac best, Resolene (Cut 50/50 with distilled water) next, Angelus High Gloss (isn't really high gloss), TanKote (Cut 50/50 with Distilled Water), Fiebings Aussie if weather protection is an issue. The worst product I've tried is Saddle Lac and then comes super sheen from tandy just a little ahead of Saddle Lac. Chief I haven't used Clear Lac, but I have used Saddle Lac. The only issue I've had so far is that it seems hard to spray on a very light coat. And too thick of a coat will make it actually flake off. In your experience, what is the difference and why do you not like the SL? Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Chief31794 Posted December 16, 2013 Report Posted December 16, 2013 I haven't used Clear Lac, but I have used Saddle Lac. The only issue I've had so far is that it seems hard to spray on a very light coat. And too thick of a coat will make it actually flake off. In your experience, what is the difference and why do you not like the SL? Same thing as you. Try some clear lac, I apply it with sheep wool and basically rub it in, it is a lacquer based finish, dries quickly, doesn't flake or crack and looks really good. There are some dyes that it will "dissolve" it seems so I use it mostly on Angelus Dyes, Fiebing Antique Dyes. I don't use it on Fiebings USMC, when I use Fiebings USMC I use Resolene (50/50) on it. Saddle Lac would probably be okay if it were not in a spray can and you could cut it 50/50 with Distilled Water. But to me it is too tacky and too thick. Like I said, thats just my opinion. Chief Quote "Life's too short to carry ugly leather"
Members OdinUK Posted December 23, 2013 Members Report Posted December 23, 2013 I've had some success with Saddle Lac, I hold the can about 8 inches above the work and spray a light coat and keep it moving reasonably fast but consistent, as if using a paint spray gun. I practiced on some scraps at first till I got the hang of what gave me a suitable thin coating. Keep the coatings thin. I usually apply one thin coat, sometimes I apply another thin coat after the first has completely dried, I tend to leave it overnight. I use this method on my back patches and its worked well (if you require a slightly glossy finish). After every couple of passes I wipe the buildup at the nozzle, if you don't do this you can get some splatter which can spoil a job. I have recently been experimenting with Cyberthrasher's advice with Resolene mixed 50/50, and I apply it with an airbrush. Ive had great results so far. Thanks! Quote Lord Of Leather
