Jeff L Report post Posted August 20, 2013 Those pesky little protrusions on the newer model firearms....Do you account for them in your holsters?... Some have them some don't and they vary in location from model to model. Do you check with your customers before molding to block them out if needed? Quote Share this post Link to post Share on other sites
Warpe Report post Posted August 20, 2013 I have not run into an indicator that protrudes to the point that it causes issues. I mold as i normally do. Anyone else run into an issue? Quote Share this post Link to post Share on other sites
George B Report post Posted August 21, 2013 Have not had any issues with the models I have done. When checking I have found the curve of the throat on the avenger allows for it without any contact. Pancakes have sort of a built in sight channel that also seems to accommodate those pesky little indicators. Quote Share this post Link to post Share on other sites
jackd942 Report post Posted September 21, 2013 I have a Taurus PT140 Millennium Pro that has the indicator on the right side. I didn't take it into account when molding and it has roughed up the inside after carrying for about a week now. I'm going to try to go back in with gum trag and fix it the best I can, but I will definitely consider that in future designs. The Springfield XDm's have never been a problem b/c they are on the top and the sight channel takes care of it. Quote Share this post Link to post Share on other sites
