intothebush
Pig Lining Pencil
Is there away to, for example to make a check book and line it with pig lining, and before glueing it cut two slits in it in the middle where the check book folds. And be able to slide a pencil or a pen in the slot? is there away to do that with still having the lining glued down with out any wrinkles? I have tried it and it keeps wrinkling up where I cut the two slits. Thanks.
where you cut it, be sure you don't have any glue in the area the pen/pencil will clip into. the problem may be that the checkbook cover may be too thin. Here are a couple of pictures of a notebook cover i made...it has a hole where the pen clip goes, and there is an area about 1 in below the hole that has no glue between the liner and the main body.
post-3307-0-33568100-1377436969_thumb.jp
post-3307-0-48577800-1377436974_thumb.jp
