Members Ken G Posted October 10, 2013 Members Report Posted October 10, 2013 I agree with the others and congratulate you on your ingenuity, and frugality. I will have to put one or two of these on my project list. Luckily I do know of a lathe or two I can borrow. Since I have never used a poly maul I can't tell you where the balance point should be and I have no idea what the sm, med, and lg Stolhman mauls weigh. I do have a better idea of how to add the weight to the head but you will need to calculate how much to add. My idea will allow you to move the weight up and down in the length of the head to change the balance point. Since they tried to teach me the metric system around 1974 I haven't used it much. I know the math conversions but I can't guess what 100 grams may feel like in my hand. I also have to make some assumptions on your dimensions and your hole saw sizes. Anyway what I am picturing is a cast lead cylinder inside the head. Lead weighs approximately 11.4 grams per cubic centimeter. If my math is correct a 2 cm diameter cylinder of lead 1 cm thick should weigh approx. 35.8 grams. If I remember right I used, Volume = (pi) x ® x ® x depth, or 3.14 x 1 x 1 x 1 x 11.4 g/cc=35.8 g. You just need to calculate how much weight you need to add and cast your cylinder the correct length. I used 2 cm diameter as that made the math real easy, pick a hole saw size and go from there. Now to cast the cylinder you need to make a simple mold. I'm thinking you could use two short pieces of lumber clamped together. Use your hole saw ( say a 2cm?) to drill a hole in the end of the clamped block in the center of the seam. Separate the pieces and square up the bottoms with a chisel. When you clamp them back together you will have a cylindrical mold. Melt your lead and carefully pour it in the mold. After a few minutes separate the mold and you should have a lead cylinder of whatever length you calculate you need. Drill a hole in the center for your threaded rod. Use the same hole saw and drill a hole out of the corresponding number of poly discs. The lead cylinder should fit in this core snuggly. Stack your poly discs back together. Since your discs are the same size you can move the weighted section up or down as needed. After typing this I realized I am assuming you have the ability to melt and cast lead. Lead is toxic so don't breath the fumes or lick your fingers. Also depending on the alloy the melting temperature is probably 500 - 600 degrees F or 260 - 315 degrees C. Either way you count it that's freaking hot so plan accordingly. You can melt small quantities in a metal can or old saucepan on a gas burner, preferably outside. There are plenty of videos on Youtube on how to cast lead. And just to scare you, don't get any moisture in the molten lead it will explode and jump right out of the pan and land on your face, Not good. Anyway, get out your calculators, tools, and safety gear and have at it. I hope this all makes sense, if not I will try to answer any questions to explain it better. Quote
Members Brandon Posted October 12, 2013 Members Report Posted October 12, 2013 (edited) Acha! I made one some years back. I first soak the leather "washers" in white glue + water (50/50). As you tighten the nut, you can add in more till the length of the handle is filled. Leave it for a day or so to dry. Don't know how to attach a pic here! Check this out: http://asailorsleath...ather-tool.html Edited October 12, 2013 by Brandon Quote
Members Redrum Posted October 14, 2013 Members Report Posted October 14, 2013 Well I thought i'd share the maul i made this weekend.Thanks for the idea to use a cutting board.I also included the head knife that i made out of a saw blade.I made mistakes on both but am very happy with the maul.I used dog collar that i decided was too thick(2 layers 9 oz.veg)for the handle and of course vinigroon.The head knife cuts 8 oz like butter. Quote
Members Geneva Posted October 14, 2013 Members Report Posted October 14, 2013 The question is for Redrum. Not this topic specifically. Why do you call yourself Murder? I think I would have selected a different nick name. Quote
Members Redrum Posted October 14, 2013 Members Report Posted October 14, 2013 It's just a name i got used to using playing online gaming. Quote
Members jmann8686 Posted October 14, 2013 Members Report Posted October 14, 2013 Ok so I love making my own tools and items. This is a great Idea and am going to give it a go. Thanks for the idea. Quote
Members halfwit Posted October 20, 2013 Members Report Posted October 20, 2013 I saw this and it reminded me of the mallet I made for much cheaper than the ones that Tandy and other retailers carry. I found a place in town that carried thick poly dowel rod and used a 3/4" allthread rod wrapped in leather for the handle. All in all it costed me about 8-9$ and works quite well. Quote
Members THE BIG RED VIKING Posted October 27, 2013 Members Report Posted October 27, 2013 (edited) Thought I would give my $3 poly maul a shot today and here is what I came up with. The one on the right with the wooden handle was the first one and since I had left over cutting board I made another with leather disc handles. Edited October 27, 2013 by THE BIG RED VIKING Quote D.I.L.L.I.G.A.S
