Members dkbutcher Posted October 13, 2013 Members Report Posted October 13, 2013 Follow up question for Dwight, do you find that one coat with this method is good and durable or do you do multiple coats? Thanks, Dave Quote
Members silverwingit Posted October 13, 2013 Members Report Posted October 13, 2013 Robert, you didn't mention what kind of dye you are using. You shouldn't have to rely on a sealer to avoid dye coming off the leather. Eventually that sealer will wear. Then what? I suggest that the right dye would leave you with far fewer problems. Dye is one product you cannot scrimp on. I suggest that you try Fiebing's Professional Oil dye. It's not cheap but it gets the job done right. Then do what Dwight suggested. Problem solved! Michelle Quote
robertmeco Posted October 13, 2013 Author Report Posted October 13, 2013 This belt was a lined hippo pre dyed with no dye on the inside Quote
Members Dwight Posted October 13, 2013 Members Report Posted October 13, 2013 Follow up question for Dwight, do you find that one coat with this method is good and durable or do you do multiple coats? Thanks, Dave Actually, . . . I very, very seldom do more than the one coat. The process that I use has never let me down. From the sound of things This belt was a lined hippo pre dyed with no dye on the inside I would be tempted to say it was dyed with a cheap water based dye, . . . and before I did anything else with that leather, . . . I'd give it a good water soaking to leach out as much of the dye as I could.Oil based, good quality dyes do not do that for the most part. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
