Members Halitech Posted October 27, 2013 Members Report Posted October 27, 2013 I started with an idea in my head and 2 different pieces of leather (18"x18") that I thought complimented each other for colors and ended up with this. Special thanks to the staff at Tandy Leather for the idea on the handle idea Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members J Hayes Posted October 30, 2013 Members Report Posted October 30, 2013 Nicely done. How did you go about sewing the bottom? It looks "boxed" or flat. Quote
Members Halitech Posted October 30, 2013 Author Members Report Posted October 30, 2013 that part I did with a machine but basically I overlapped the 2 pieces I was using for the front and back and cut it so the extra would fold in on itself to give it a flat bottom and more support on the bottom. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members J Hayes Posted October 30, 2013 Members Report Posted October 30, 2013 I like it. The flat bottom is nice. How did you do the sidez then. Quote
Members Halitech Posted October 30, 2013 Author Members Report Posted October 30, 2013 almost the same way. I glued everything first and then sewed it. if you were to take a piece of paper, lay it landscape and cut 2 slits 2" each from the bottom and the edges, to the top you would have the only cuts I made until I did the flap. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
