Moderator Wizcrafts Posted November 16, 2013 Moderator Report Posted November 16, 2013 Well it is still pulling the bottom thread up for about 8-10 stitches then back to normal. when it stitches like normal it looks great though. Something happens during those stitches to cause the tension to go awry. The problem is either in the bobbin/bobbin thread, or the top thread and its path. Watch the top thread as you sew a long strap. You may see it twist around a post, or even itself. Make sure that the bobbin thread feeds under the bobbin spring and stays under it. Load the bobbin so it feeds counterclockwise into the slot in the bobbin basket. Check the bobbin to see if the starting thread has a stub sticking out that might be catching on the case, basket, or shuttle. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Red Cent Posted November 16, 2013 Members Report Posted November 16, 2013 What Wiz said. I found that when that problem happened, the thread "caught" on the spool thread. Any time the thread is impeded, no matter how little, it creates super tension in those discs especially the lower one. Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Members tnawrot2 Posted November 16, 2013 Members Report Posted November 16, 2013 You said you are using a piece of scrap leather, if you are using any belly leather it has different consistencies and firmness that would cause your problem. Quote
Members TKLeather33 Posted November 16, 2013 Author Members Report Posted November 16, 2013 You know I am using some pretty bad chap scrap and I was wondering if that was it as well. I put some projects together last night and stitched em this morning and it went well. But I have run a bunch off of the brand new spool, and adjsuted a few tensions as well so maybe we cured it. Thanks for all of the input and help guys Quote
