Members debinarizona Posted November 18, 2013 Members Report Posted November 18, 2013 I have a Cowboy Model 227R machine and have been oiling it where I think it needs it. However, I don't feel comfortable that I'm getting it oiled properly. The paperwork I have is a copy of a copy, etc. so can not really tell exactly where it needs to be oiled. Is there someone out that that could help me with this? Deb in Arizona Quote
dirtclod Posted November 18, 2013 Report Posted November 18, 2013 Put a few drops of oil in the all the holes you see especially the ones with red paint around them. Most of the new machine have red paint anyway. I generally put a couple of drops in the shuttle to. Quote I'm old enough to know that i don't know everything.
Members Greystone Posted November 19, 2013 Members Report Posted November 19, 2013 if it moves and looks like it can be oiled on a regular basis it is as well as the marked points Quote www.facebook.com/pages/Greystone-Leather www.etsy.com/shop/GREYSTONELEATHER
Moderator Wizcrafts Posted November 19, 2013 Moderator Report Posted November 19, 2013 If you haven't already done so, open the faceplate and place a drop of oil into the tiny oil holes on the crank arms inside the head. If you can't see a hole, drop the oil at the front or back of where the outer crank encloses an inner stud. Place oil up at the top of the needle bar, where it pivots. There is sometimes a wick inside that pivot point. After oiling inside the head, place paper towels under the feet for a while. There will be a lot of dripping! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members SteelcityK9Cop Posted November 19, 2013 Members Report Posted November 19, 2013 Since we are talking oil.... When you oil the red dot spots... are you just putting a drop in the hole or are you using the oil container's long tube to get into the hole to where you touch a shaft to put the drop there? Also, how often are we doing the "full oil" vs. the red dot oil? Quote
dirtclod Posted November 19, 2013 Report Posted November 19, 2013 I just put a few drops in the hole and oil everthing when i oil. Quote I'm old enough to know that i don't know everything.
Moderator Wizcrafts Posted November 19, 2013 Moderator Report Posted November 19, 2013 The only consequence of over-oiling a manually oiled sewing machine is dripping oil. If you are sewing black bridle leather the oil has no effect. Otherwise, keep a cloth or paper towel under the feet and needle to absorb the oil dripping down the needle bar. Wipe oil off the presser bar that is visible under the head. Wipe dripping oil where you see it, but leave the rest inside the machine. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members debinarizona Posted November 19, 2013 Author Members Report Posted November 19, 2013 Since we are talking oil.... When you oil the red dot spots... are you just putting a drop in the hole or are you using the oil container's long tube to get into the hole to where you touch a shaft to put the drop there? Also, how often are we doing the "full oil" vs. the red dot oil? I have only been doing the "red dot oil". What does the "full oil" entail? Thanks for your help - you are awesome! Quote
Members debinarizona Posted November 19, 2013 Author Members Report Posted November 19, 2013 The only consequence of over-oiling a manually oiled sewing machine is dripping oil. If you are sewing black bridle leather the oil has no effect. Otherwise, keep a cloth or paper towel under the feet and needle to absorb the oil dripping down the needle bar. Wipe oil off the presser bar that is visible under the head. Wipe dripping oil where you see it, but leave the rest inside the machine. I have oiled everything that moves - that I can see - plus the "red dot" places. Do I need to unscrew anything to get to the "hook system" etc. I'm thinking that needs to be oiled somehow - (just put a little where it moves?). Is there a video available somewhere to help novices like me? Thanks for your help - you guys are all awesome!!!!! Since we are talking oil.... When you oil the red dot spots... are you just putting a drop in the hole or are you using the oil container's long tube to get into the hole to where you touch a shaft to put the drop there? Also, how often are we doing the "full oil" vs. the red dot oil? I use the long tube when I do the "red dot" oiling. Don't know anything about the "full oil"..............any info would be welcome! Quote
dirtclod Posted November 20, 2013 Report Posted November 20, 2013 When i said a full oil, i oil everthing that moves. Quote I'm old enough to know that i don't know everything.
