Thanks for everyone's advice.
I had strongly considered a flat bed and almost pulled the trigger. Then, I thought that the cylinder arm --with a flat bed attachment-- might be a more versatile machine, seeing that I am not quite sure where this is all leading. I tend to drive myself "nuts" with these decisions.
My reasoning is that If I spend a bit more money now on the cylinder arm, I was hoping to lessen the chances of needing another machine in the near future. Wiz helped me see that I was overshooting in my range and that a light to medium weight (like the CB227r) is a better fit for me. I do not see myself doing really heavy leather work. That is when I narrowed it down to the TechSew 2700 and the CB227R.
Am I correct that the cylinder arm with the flatbed gives me the most versatility? Do I loose anything by not buying a flat-bed only machine?
I'm almost there hope.
Thanks Again For Your MUCH Appreciated Guidance!
Bruce
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
It is easy to make a flat bed for any machine in a couple of hours.
Darren Brosowski
Bruce
Yes a cylinder machine with a flatbed will give you the most versatility. Cylinder will be used for sewing bags, curved items, flatbed attachment will be used when you're sewing belts, leather garments and other long/large items.
Ron
Techsew Industrial Sewing Machines
Call toll-free: 866-415-8223
Visit www.techsew.com
I agree with Ronnie. The Cylinder arm machines are much more versatile than the flatbeds and with the correct needle and thread you will be able to sew lighter weight fabrics as well. Steve
Thank You
Steve Tayrien
Leather Machine Co., Inc.
2141 E. Philadelphia St. Unit "U"
Ontario, California 91761
1-866-962-9880
http://www.leathermachineco.com
cobra@leathermachineco.com
Thank You - Thank You
I took the plunge and ordered a TechSew 2700 Pro.
Because everyone's help, I believe that I made the right choice, finally.
A special thanks to Wiz.
Bruce
Bruce
You're welcome. Did you order a flat bed attachment with it?
Posted IMHO, by Wiz
Yes the "Pro" model has a few extra attachments:
SmartServo-NP Needle Position Motor
TLG Laser Guide
Swing Down Roller Guide
Flatbed Table Attachment.
Since 2005, my passion was motorcycles. I hung up the two wheels and now I am hooked on leather craft. I usually "jump in" with both feet and don't look back. So, I have lots of learning and practice ahead.
Thanks to you and everyone else, I am off to a good start.
Bruce
  • 3 weeks later...
Bruce I would love to hear from you after you get a chance to try the Techsew 2700 Pro as this is the machine that I have been thinking about purchasing also. It seems to have everything that I need for the work I would like to do and they seem to have great service from what I have heard so far. It's a big decision , I have been looking for some time now
Hello Babbs,
I might not be the best judge of sewing machines because this is my first one. I had problems getting started but it was All User Error. Techsew has been very responsive to all my questions and problems with both emails and phone calls. Good support is key for me, especially since I am a "rookie".
Now, the sewing machine is sewing great into 2 pieces of 4oz. leather. I expect that I will be very happy with this machine.
I like the lase guide. it helps me keep the leather sewing in a straight line. I need all the help I can get. I am still waiting for the flatbed accessory, It is on back order. So, I cannot comment on that. I am very glad this accessory is included in the Pro version.
The only issue I have left is with the swing arm edge guide. In the down position, it falls about 3/4 in. to 1 in. short of being inline with the needle. So, at the start of sewing I cannot bump up against the guide until I sew through 3/4 in. of leather. I should find out tomorrow what the problem is (probably me again). I will let you know what I find out.
If you have any questions, feel free to ask!
Sorry I couldn't be more help.
Bruce
Update on Techsew 2700 Pro swing arm edge guide
Apparently, the roller cannot be modified to be in line with the needle. I really wanted a different configuration.
So, I figured out a solution that puts the roller guide exactly in line with the needle.
Basically, I installed the bracket backwards. These are the following steps:
1. Remove the bracket (2 bolts) that holds the guide, Rotate the bracket 180 degrees.
2. Add spacers (4 washers totaling 3/4 inch thick) to each bolt hole.
3. Replace the bolts with 3/4 in. length and bolt on the bracket.
4. Slide back on the swing arm.
What's nice is the set screws to stop the swing arm from sliding are now facing the front. Get a long allen wrench to easily reach the set screws.
Everything else is working as advertised. And, with a great support team behind their products, I am a very satisfied customer.
Thanks,
Bruce
