Tex Shooter
Stitching Pony Concept
I had not seen a pony configuration like this, so I just threw together this pony with scrap to try it out. It is not finished and I will either tear it down and re-do it or tweak it quite a bit. It was meant as a concept prototype. The idea behind it is to clamp it to a table and then slide up to it to stitch. The pony as it sits works, but it could use some tweaking. A bolted on 2 inch by 1/8 aluminum angle Is what holds the clamp to the table clamping board. The tips have Barge glued vegetable tip inserts. It is strong and does not flex around. I will put more gap at the bottom for clearance and about make 2 or 3 inches shorter overall. The angle is mounted upside down to give more throat. I used a hinge at the bottom and found out that was a mistake. This is my first attempt at making a stitching pony and I have learned a lot. -- Tex
post-42291-0-82685500-1387718495_thumb.j
