Ok so I just received a new cobra class 4. I am sure I'll have a thousand questions.. But here is a few.
1. Does the bobbin color have to match the thread color.
2. Do u always start a run with a back stitch ? Or if u stitch around the project and overlap is that enough to lock the stitches in.
3. Is there a video or reference that explains all the different plates and walking feet ?
1/ No. In fact when you get the machine I suggest you spend a week or two playing with different thickness materials using black and white thread. This will show up tension issues clearly and you will be forced to learn how to set tensions
2/ If you are going around a project then backtacking is not necessary. As you get to the previous stitching you may need to lift the foot to get into the original set of holes but ( and others will disagree) that is only critical on high stress parts of the job
3/ NFI
