Leprechaunleather
What Exactly Is Tan Kote ?
Like the title says ... what is it and what is it used for ? i hear alot about it but im still not sure
Tan Kote over dye will give your leather a nice mellow look.
You have to put it on in light coats, if you wipe the leather more than twice you'll remove dye with it.
I put it on quick and let it dry before applying it again.
I have it in the shop and use it when Clear Lac isn't quite what i want. I cut it 50/50 with distilled water and put it on in light coats, works okay when I want to use a water based finish.
Chief
