Members mproberts Posted February 22, 2014 Members Report Posted February 22, 2014 (edited) Hello all - first post here, but have been lurking/reading for awhile. My wife is the creative side of sewing and now leather work. She is currently focused on leather hand-bags and some apparel. I'm the researcher side of things (engineer during the day) and really enjoy the electro-mechanical pieces and parts of her hobby. We realized her existing hobby machine was not adequate for sewing leather, especially anything of thickness or multiple layers. We did play around briefly with a vintage Necchi that had a little more presser foot lift than her her main machine, but it needed work to simply stitch reliably, was not a walking foot, and would need a motor upgrade. As we live in Rochester, NY we were somewhat limited in going out to a seller and testing, touching and seeing the options. Our options to visit a dealer and see a range of machines were Toronto, NYC or Pittsburgh - and although a good excuse for a fun weekend, we just couldn't fit it in. So we've done a lot of reading on our options for an upgrade, and this forum has been immensely helpful. So we were back and forth on several machines and talked to several sellers. We reviewed the Consew CP206-R, Consew 206RB5, Juki DNU-1541S, Juki DU-1181N, etc. We had a few long conversations with a dealer in Pennsylvania and discussed prices and shipping and warranty/service, parts availability, etc. Our high-level specs: Commercial, or near-commercial grade Walking-foot, single stitch High presser-foot height Servo Motor - ideally 3/4 horse (120v) Safety clutch Ideally a package from manufacturer (not pieced together) Interchangeable parts and options for feet and accessories After all of that, we decided on the Reliable MSK-1541S. This is a knock-off of the Juki DNU-1541S I believe. After all of the above, my general questions are around whether anyone here has any experience with Reliable or specifically their MSK-1541S? The price was very good comparatively and seems to come well equipped (SQ5000 servo motor, plywood-topped table, Light, etc). Reliable web site for specs on head: (http://www.reliablec...tch/MSK-1541S_3) Thanks for any thoughts, tips or advice here! Edited February 22, 2014 by mproberts Quote
Members mproberts Posted February 22, 2014 Author Members Report Posted February 22, 2014 While not exactly on topic with my post above, I wanted to share a Thread/Needle chart I grabbed/modified that might be helpful to some of us beginners. Since we are new to this, I thought this might be appropriate here since buying a new machine and getting an understand of all the supporting bits is also important. Any corrections or clarifications to the chart below is appreciated! Quote
Moderator Wizcrafts Posted February 22, 2014 Moderator Report Posted February 22, 2014 The Reliable is a standard upholstery grade walking foot machine. As such, expect it to max out with #138 thread, possibly even as thick as #207 on top and 138 in the bobbin. It will sew up to 3/8 inches of material. If this meets your needs, you're good to go. I see that you highlighted thread sizes 92 through 277 in the chart you posted. Do not try using #277 in that machine. It is not built to handle it. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members mproberts Posted February 22, 2014 Author Members Report Posted February 22, 2014 Thanks for the feedback. I believe she will be fine with the #138 thread as a max for what she is doing and plans to do. How does the 3/8" max for material correlate to the vendor claim/spec foot lift of 9 mm (hand), 16 mm (knee)? Quote
Moderator Wizcrafts Posted February 22, 2014 Moderator Report Posted February 22, 2014 Thanks for the feedback. I believe she will be fine with the #138 thread as a max for what she is doing and plans to do. How does the 3/8" max for material correlate to the vendor claim/spec foot lift of 9 mm (hand), 16 mm (knee)? The "lift" of the hand lifter lever or knee, or floor pedal is not the same as the amount of material that can be sewn. All walking foot machines must lift at least 1/8 to 3/16 inches more than they can actually sew. This allows the feet to alternate up and down. In you case, that amount is 10 mm, or 3/8 inch. The length of the needle and thickness of the feet determines the maximum thickness that can be sewn. If you exceed that limit, you end up with skipped stitches, or broken needles, or bent crank arms, or a broken thread guide on the bottom of the needle bar. If the needle bar hits the presser foot in operation, it will get knocked out of time. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members mproberts Posted February 23, 2014 Author Members Report Posted February 23, 2014 That makes perfect sense! Thank you. Quote
Members mproberts Posted March 1, 2014 Author Members Report Posted March 1, 2014 So an interesting turn of events here. I won't share vendor names, but we went ahead and ordered the Reliable at a price of $1050 plus $150 to ship. What arrived is what appears to be a Juki DNU-1541S clone. And I mean maybe counterfeit? It does not look quite like the Reliable above, but exactly like a Juki DNU-1541S. The giveaway is the plate riveted to the front. It says: DNU-1541S Juki Corporation Made in Japan MFG. No. (Blank) So there is no serial number on the plate, and the tag looks different than the 1541 plates I see on the web. There are also no printed names on the casing like shown in both Reliable and Juki photos. The whole thing came assembled, set up and tested. And the wife tested it out and it works very well. So we have a call in to the vendor to see what this is all about... The vendor does have a very large presence and has been great to work with. They said the price of $1050 was due to warehouse consolidation and we had picked a great time to buy. Anyone else run across (potentially) counterfeit machines? Quote
Members Gregg From Keystone Sewing Posted March 1, 2014 Members Report Posted March 1, 2014 So an interesting turn of events here. I won't share vendor names, but we went ahead and ordered the Reliable at a price of $1050 plus $150 to ship. What arrived is what appears to be a Juki DNU-1541S clone. And I mean maybe counterfeit? It does not look quite like the Reliable above, but exactly like a Juki DNU-1541S. The giveaway is the plate riveted to the front. It says: DNU-1541S Juki Corporation Made in Japan MFG. No. (Blank) So there is no serial number on the plate, and the tag looks different than the 1541 plates I see on the web. There are also no printed names on the casing like shown in both Reliable and Juki photos. The whole thing came assembled, set up and tested. And the wife tested it out and it works very well. So we have a call in to the vendor to see what this is all about... The vendor does have a very large presence and has been great to work with. They said the price of $1050 was due to warehouse consolidation and we had picked a great time to buy. Anyone else run across (potentially) counterfeit machines? I want to tread lightly here, but what, potentially is counterfeit about this machine? It was never stated up front that it was a genuine Juki DNU-1541S made in Japan. Are you inferring that this machine is not a genuine Reliable Corp. machine? What I'm saying is that this may well be the same machine from the same factory as the Reliable that is of course different the Japan made Juki DNU-1541S. And, by both appearance and even model number, I would think that it would only be assumed that this is a copy of the Juki original. Pics? Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members mproberts Posted March 1, 2014 Author Members Report Posted March 1, 2014 Pics attached. And please don't think I'm trying to cause a big stir - or call out any dealer. I will say this is not from any dealer I have seen mentioned on this site though. Also - we are not unhappy, just curious what this actually is. We do not believe this is a unit from Reliable - at least based on the info we were given, and pics from the Reliable site. Quote
Members Gregg From Keystone Sewing Posted March 1, 2014 Members Report Posted March 1, 2014 (edited) I think the phrase 'Don't look a gift horse in the mouth' applies here. I think that looks like a good machine, and a good motor setup. I would not be surprised if this is a machine that Reliable sold before they changed their machines' frame. If that's the case, that's a good machine and a more than fair price. Enjoy, seems like a nice setup. Edited March 1, 2014 by Gregg From Keystone Sewing Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
