Members Jaystacy Posted March 13, 2014 Members Report Posted March 13, 2014 The below pics are both resisted with RTC and Sheridan brown antique paste used. I have not sealed it yet but am wondering if there is a way to strip the top layer resist so I can add a bit more oil to darken the leather a little more. Or if yellow saddle soap will help to darken after I seal it?! Quote
Members keplerts Posted March 13, 2014 Members Report Posted March 13, 2014 Jaystacy, I would simply add light coats of oil to the backside until you reach the desired tone. Put a coat on and let it sit overnight. This gives the oil a chance to soak through. If not dark enough then repeat. Don't make the mistake of putting lots of oil on all at once. Be patient! Tom Quote
Members Jaystacy Posted March 13, 2014 Author Members Report Posted March 13, 2014 Thanks Tom I had concidered that but wasn't sure if that would work. I will give it a try Quote
Contributing Member Bob Blea Posted March 13, 2014 Contributing Member Report Posted March 13, 2014 To answer the other part of your question, I have stripped the resist off an antiqued project by using denatured alcohol and lightly scrubbing. My resist was Wyosheen (basically Neat Lac or Clear Lac) but it should work with RTC as well. Hope this helps, Bob Quote
Members Jaystacy Posted March 14, 2014 Author Members Report Posted March 14, 2014 Ok Bob ty if oil from back doesn't get it how I'd like ill go your way :-) Quote
