http://www.sew-europe.co.uk/ankai_2972.htm
supposed to be exact copies, that part should be good, but guess it really depends on quality of materials used
what do you guys think
nobody tried one?
I may need to replace my old 29k, In which case i need something very similar multi directional, and preferably in the uk
any ideas
nobody tried one?
any ideas
My advice is try it before you buy it to ensure that it sews a good stitch. Inspect the body castings for sharp edges that might cause problems with the motion of the various parts. Make sure the presser foot drive ring rotates smoothly 360 degrees. The presser foot should not have measurable slack forward and backward, or stitch length will suffer above 3mm. Get a warranty in case something bad happens after you get it home.
Posted IMHO, by Wiz
thank you wizcrafts. things are looking up a little today, Ive replaced all springs on the 29k,, just resetting the tensions, its starting to sew thin leather now, (big improvement) but not properly, hoping its just the tension now, but will know tomorrow.
will know tomorrow, hoping its sorted but if not I'll try to see if i can inspect
thanks mate
Al
Edited by needles
All good advice from Wiz. Wiz is....well.....a Wiz at this stuff! Also, what is the price they are asking?
Bob
its ridiculously cheap for new, to be honest, thats why asking if anyone had tried or seen one, only £499.00 plus vat at 20%
if i can get the time Ill try and arrange a visit but they are about 4-5 solid hours drive away,
I suspect it is made in Taiwan as the casting looks a bit neater than the Chinese machine but I could be wrong.
Open the rear cover plate and stick your finger in. The Chinese machines usually have bits of swarf (metal shavings) floating around and this suggests nonexistent quality control.
Darren Brosowski
thanks Anne that's worth knowing
Just what my Singer 29K-72 silver blue color has together with allot of other casting errors inside the head too. My advise is getting an Adler class 30. LOL
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Its not an exact replica of a 29K-72. The -72 has a long arm and big bobbin, the machine in the picture is a short arm with small bobbin. Not that this matters much anyway. This is a cheap clone clone model, it do not cost much regardless of brand. Try out machine and support.
Good luck
Tor
Tor
