When sewing a wallet the stitch per inch changes with the thickness of leather from 1/8 of an inch where the interiors are to 1/16 where they aren't.
Would you dial in a longer stitch per inch for the thinner material or just keep it the same and live with the change in stitch on the wallet?
No, that's not right. You shouldn't notice any change in stitch length for such thin leather. Are you using the feed dog, or just the slotted plate?
Posted IMHO, by Wiz
Try backing off the pressure spring, bobbin and top disk tensions. Thin material has a harder time feeding evenly if the thread is pulling it back, or the feet hold it too tightly.
Posted IMHO, by Wiz
Thanks Wiz, the feed dog is in with the standard plate.
Now that you're telling me it shouldn't change stitch length I'll try it on some scrap leather before I change any settings, the problem I had was with stingray.
UPDATE
It's the material, leather stitching is good on leather.
Stingray is a challenge!
post-19342-0-20556900-1395664718_thumb.j
Another problem solved, thanks again.
Edited by Tree Reaper
