How do you set tension on a check spring on the cowboy 4500, the only adjustment I see is in the travel on not the tension?
Loosen the hex nut on the back of the housing for the bottom disks, then turn the split shaft one way or the other to change the tension on the check spring. Lock the nut down when you are happy with the spring tension.
Posted IMHO, by Wiz
Is the split shaft threaded into the machine then as well?
The shaft goes through a hole in the frame. Can't recall if it is smooth or threaded. The nut on the back stops it from turning.
Posted IMHO, by Wiz
Thanks Wiz,
I suspect it's a hole where the spring and washers keep tension on the nut.
Good to know, I didn't see that adjustment in the manual.
Justin, you may want to try a different spool of thread, just to be sure. Steve
Thank You
Steve Tayrien
Leather Machine Co., Inc.
2141 E. Philadelphia St. Unit "U"
Ontario, California 91761
1-866-962-9880
http://www.leathermachineco.com
cobra@leathermachineco.com
Am I seeing things? it looks like the thread is going from right to left through the needle. Might be time for me to get some glasses.
